Intermec SG20 General Duty Imager - Wireless Handheld Barcode Scanner
Quicklinx: 8XCVWS00 Mfr#: SG20B1D-USB002
Type: Barcode scanner
Form Factor: Handheld
Compatibility: PC
£372.13 ex VAT
£446.55 inc VAT
Speed up the customer checkout experience with the SG20 handheld scanner, available with the industry's fastest 2D bar code imaging technology for quick, flawless scans - every time. Ergonomically designed for the needs of countertop scanning applications in retail, office, library, and light manufacturing.
The Intermec SG20 is an affordable, high-performance handheld scanner available in a range of models suited to the demands of general purpose countertop scanning.
  • Perfectly matched to your needs
    Select between Bluetooth wireless for up to 10 meters of range, or the simplicity of tethered (cabled) connectivity. Now you can standardize on a single scanner family across your operation, while providing employees with just the right capabilities they need for their specific tasks.
  • Setting a new design standard
    The stylish design of the SG20 sets it apart from traditional gun-shaped handheld scanners. Careful attention to detail and extensive usability testing have resulted in a scanner that is not only aesthetically pleasing on any countertop, but also optimized for user comfort, with a natural smooth grip and trigger location. The arching profile of the SG20 is perfect for tight spaces and the over-sized multi-color LED provides a bright, visual cue to confirm a successful scan, which can be helpful in noisy environments. In fact, the LED can be programmed to match the decor of your storefront.
  • Part of a complete Intermec solution
    The SG20 can be quickly and easily configured with Intermec's exclusive EasySet PC programming tool. In just a few clicks, this Windows-based utility can print programming bar codes for custom configurations. Adjust security settings, symbologies, beeper tone and volume, LED color - even set up advanced data-editing routines.
Intermec SG20B General Duty Imager - barcode scanner
Barcode scanner - handheld - Bluetooth 2.1 EDR - decoded
Minimum Bar Width
6 mil
Scan Element Type
Linear imager
Wireless
Wireless Connectivity
Bluetooth 2.1 EDR
Lithium Ion
6.1 cm x 20 cm x 6.5 cm
175 g
3-year warranty
Barcode
Interface Type
Bluetooth 2.1 EDR
Minimum Bar Width
6 mil
Scan Element Type
Linear imager
Scan Mode
Single-pass
Max Working Distance
50 cm
Decode Capability
Code 93, Matrix 2 of 5, Code 39, GS1 DataBar, Telepen, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 93i, GS1 DataBar Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Limited, Standard 2 of 5, GS1 DataBar Composites
TTL Decoding
Decoded
Wireless
Bluetooth 2.1 EDR
1 x USB - Type A
Cradle
1 x USB cable - 1.83 m
UL, C-Tick, CISPR 22 Class B, EN55022, NOM, ICES-003 Class B, FCC Part 15 B, RoHS, WEEE, ANATEL, IEC 60529 IP30, REACH, CQC
Power adapter - external
Lithium Ion
6.1 cm
20 cm
6.5 cm
175 g
Limited warranty - 3 years
50 °C
5 - 95% (non-condensing)
Drop Specification
1.2 m to concrete
Compatibility: PC
Brand: Intermec
Price Range Ex VAT: 300 - 500
