The Intermec PC43t is designed to set a new standard in user friendliness and flexibility. PC43t features an icon-graphics user interface for maximum ease of use. PC43t features low cost and fast operation which makes it a smart choice for light-duty labeling applications where users need a reliable, easy-to-use printing solution.
- Intermec PC43t - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 2.7 kg
- Localisation
- Europe
- Max Media Size
- Roll (11.8 cm)
- Min Media Size (Custom)
- 19 mm
- Max Media Size (Custom)
- 118 mm
- Print Speed
- Up to 203.2 mm/sec - max speed - Roll (11.8 cm)
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB
- RAM Installed (Max)
- 128 MB DDR2 SDRAM
- Flash Memory Installed (Max)
- 128 MB
- Language Simulation
- Intermec Printer Language (IPL), EPL2, Intermec Fingerprint, Intermec ESim, DSim (Datamax Interpreter), ZSim, Extensible Mark-up Language (XML), DPL
- Barcodes
- UCC/EAN-128, Code 49, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, MicroPDF417, Code 16K, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, Grid Matrix Code
- Media Type
- Labels, self-adhesive labels, linerless labels
- Fonts
- OCR-A, OCR-B
- Realtime clock, adjustable gap sensor
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 21 cm x 28.1 cm x 22.7 cm
- Printer Type
- Label printer - thermal transfer - monochrome
- Localisation
- Europe
Printer
- Print Speed
- Up to 203.2 mm/sec - max speed - 203 dpi - Roll (11.8 cm)
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB
- 203 dpi
- Fonts
- OCR-A, OCR-B
- Barcodes
RAM
- 128 MB
- Technology / Form Factor
- DDR2 SDRAM
Flash Memory
- Flash Memory
- 128 MB
Media Handling
- Media Type
- Max Media Size
- Roll (11.8 cm)
- 19 mm
- 118 mm
- Media Sizes
- Roll (11.8 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 1727 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38.1 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.8 cm)
- Connections
- 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- FCC Class A certified, UL, TUV GS, C-Tick, BSMI, cUL, GS, EN55024, CISPR 22, EN55022 Class B, CCC, EMC, IEC 60950-1, KCC, cULus
- Power Device
- Power adapter - external
- Frequency Required
- 50 - 60 Hz
- Software Included
- Drivers & Utilities
Environmental Standards
- ENERGY STAR
- 1-year warranty
- 5 °C
- 40 °C
- 10 - 80%
- 21 cm
- 28.1 cm
- 22.7 cm
- 2.7 kg
