The EasyCoder PD42 is a dependable and versatile printer suitable for medium duty applications in manufacturing, transportation and warehousing environments. With all-metal chassis and covers, proven printing mechanics and powerful electronics, it provides the sturdiness and performance your business depends on.
The EasyCoder PD42 is the first Intermec printer to feature a monochrome, graphical display, which allows users to set up, configure and fine tune printing parameters without having to send commands through the host, saving time. The display working in concert with the status lights provides the user specific feedback if the printer is in an off-line state.
The ability to use any Intermec printer language and emulate other printer protocols makes the EasyCoder PD42 both fully compatible with other Intermec equipment and a cost-effective "drop-in" printer replacement in almost any non-Intermec firmware environment.
Using Fingerprint programming language, the EasyCoder PD42 can change with the application. There's no need to replace the printer when you upgrade your software environment - the printer will adapt. The EasyCoder PD42 keeps your options open and protects your investment.
The EasyCoder PD42 can print demanding crisp variable-data labels continuously at 150 mm/s (6 ips). It takes industry standard 200-mm (8-in) rolls of labels and 450 m (18 000 in) of ribbon, reducing downtime for loading media to a minimum.
The printer accepts a wide range of paper types in different thicknesses, as well as both ink-in and ink-out ribbon. In addition the EasyCoder PD42 offers many Smart Printing features normally found only in high-performance printers. By adding Intermec's LabelShop Pro and XMLLabel , the EasyCoder PD42 will be fully provisioned for XML printing environments.
Support for Unicode fonts and Intermec Ready-to-Work indicator are standard - all at an affordable and competitive price. Networking is an increasingly important user requirement but still a rare feature in this printer class. The EasyCoder PD42 offers EasyLAN high-speed, multi-channel Ethernet as a standard choice.
An open and accessible design makes media loading quick and easy, and the print head can easily be replaced without using any tools.
- Intermec EasyCoder PD42 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 13 kg
- Max Media Size
- Roll (11.8 cm)
- Max Media Size (Custom)
- 118 mm
- Print Speed
- Up to 150 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- Parallel, USB, LAN, serial
- RAM Installed (Max)
- 16 MB SDRAM
- Flash Memory Installed (Max)
- 8 MB
- Card Reader
- Language Simulation
- Intermec Printer Language (IPL)
- Barcodes
- Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 16K, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, EAN-UCC Composite, Code 128B, Code 128C, Code 128A
- Media Type
- Labels, continuous forms, fanfold paper, tag stock, tickets
- Label Taken Sensor (LTS)
- Networking
- Print server - Ethernet, Fast Ethernet
- 27.3 cm x 45.3 cm x 27 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Up to 150 mm/sec - max speed - 203 dpi
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- Fonts Included
- 15 x TrueType
- Barcodes
RAM
- 16 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 8 MB
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Media Handling
- Media Type
- Max Media Size
- Roll (11.8 cm)
- 118 mm
- Media Sizes
- Roll (2.5 - 11.8 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 1520 mm
- Roll Maximum Outer Diameter
- 213 mm
- Roll Core Diameter
- 76 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.8 cm)
- Networking
- Print server
- Data Link Protocol
- TCP/IP, UDP/IP, ICMP/IP, LPR/LPD
- Remote Management Protocol
- SNMP 2, SNMP, HTTP
- WEP, WPA, WPA2
- Connections
- 1 x USB - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45 , 1 x parallel
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x ribbon
- UL, cUL, NOM, FCC, RoHS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities, Intermec LabelShop
- 5 °C
- 40 °C
- 20 - 85%
- 27.3 cm
- 45.3 cm
- 27 cm
- 13 kg
