Product
Intermec EasyCoder PD42 Mono Direct Thermal Label Printer
Quicklinx: 9F63WS00 Mfr#: PD42BJ1100002020
The EasyCoder PD42 is a dependable and versatile printer suitable for medium duty applications in manufacturing, transportation and warehousing environments. With all-metal chassis and covers, proven printing mechanics and powerful electronics, it provides the sturdiness and performance your business depends on.
The EasyCoder PD42 is the first Intermec printer to feature a monochrome, graphical display, which allows users to set up, configure and fine tune printing parameters without having to send commands through the host, saving time. The display working in concert with the status lights provides the user specific feedback if the printer is in an off-line state.
The ability to use any Intermec printer language and emulate other printer protocols makes the EasyCoder PD42 both fully compatible with other Intermec equipment and a cost-effective "drop-in" printer replacement in almost any non-Intermec firmware environment.
Using Fingerprint programming language, the EasyCoder PD42 can change with the application. There's no need to replace the printer when you upgrade your software environment - the printer will adapt. The EasyCoder PD42 keeps your options open and protects your investment.
The EasyCoder PD42 can print demanding crisp variable-data labels continuously at 150 mm/s (6 ips). It takes industry standard 200-mm (8-in) rolls of labels and 450 m (18 000 in) of ribbon, reducing downtime for loading media to a minimum.
The printer accepts a wide range of paper types in different thicknesses, as well as both ink-in and ink-out ribbon. In addition the EasyCoder PD42 offers many Smart Printing features normally found only in high-performance printers. By adding Intermec's LabelShop Pro and XMLLabel , the EasyCoder PD42 will be fully provisioned for XML printing environments.
Support for Unicode fonts and Intermec Ready-to-Work indicator are standard - all at an affordable and competitive price. Networking is an increasingly important user requirement but still a rare feature in this printer class. The EasyCoder PD42 offers EasyLAN high-speed, multi-channel Ethernet as a standard choice.
An open and accessible design makes media loading quick and easy, and the print head can easily be replaced without using any tools.
Intermec EasyCoder PD42 - label printer - monochrome - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
13 kg
Max Media Size
Roll (11.8 cm)
Max Media Size (Custom)
118 mm
Print Speed
Up to 150 mm/sec - max speed
Max Resolution (B&W)
203 dpi
Parallel, USB, LAN, serial
RAM Installed (Max)
16 MB SDRAM
Flash Memory Installed (Max)
8 MB
Card Reader
Language Simulation
Intermec Printer Language (IPL)
Barcodes
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 16K, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, EAN-UCC Composite, Code 128B, Code 128C, Code 128A
Media Type
Labels, continuous forms, fanfold paper, tag stock, tickets
Label Taken Sensor (LTS)
Print server - Ethernet, Fast Ethernet
AC 120/230 V
27.3 cm x 45.3 cm x 27 cm
Printer Type
Printer
Print Speed
Up to 150 mm/sec - max speed - 203 dpi
Built-in Devices
Status LCD
Wired
203 dpi
Language Simulation
Fonts Included
15 x TrueType
Barcodes
RAM
RAM Installed (Max)
16 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Card Reader
Card reader
Supported Flash Memory Cards
CompactFlash Card
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
118 mm
Media Sizes
Roll (2.5 - 11.8 cm)
Max Printing Width
104 mm
Max Printing Length
1520 mm
Roll Maximum Outer Diameter
213 mm
Roll Core Diameter
76 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, LPR/LPD
Remote Management Protocol
SNMP 2, SNMP, HTTP
Security Protocols & Features
WEP, WPA, WPA2
1 x USB - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45 , 1 x parallel
1 x USB cable
Consumables Included
1 x ribbon
UL, cUL, NOM, FCC, RoHS
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, Intermec LabelShop
5 °C
20 - 85%
27.3 cm
45.3 cm
27 cm
13 kg
