Product
Intermec EasyCoder PD41 Label Printer
Quicklinx: 7B3WWS00 Mfr#: PD41BJ1000002020
The EasyCoder PD41 is a dependable and versatile printer suitable for medium duty applications in manufacturing, transportation and warehousing environments. With all-metal chassis and covers, proven printing mechanics and powerful electronics, it provides the sturdiness and performance your business depends on.
The EasyCoder PD41 can print demanding crisp variable-data labels continuously at 150 mm/s (6 ips), thereby outperforming all other printers in its class. It takes industry-standard 200-mm (8-in) rolls of labels and 450 m (18 000 in) of ribbon, reducing downtime for loading media to a minimum. The printer accepts a wide range of paper types in different thicknesses, as well as both ink-in and ink-out ribbon.
In addition the EasyCoder PD41 offers many Smart Printing features normally found only in high-performance printers Multi-language capability and Intermec Ready-to-Work indicator are standard - all at an affordable and competitive price.
PrintSet, a PC-based setup tool, makes installation and setup of the EasyCoder PD41 intuitive and easy. The one-button interface makes the printer easy to operate and well protected against unintentional changes of the setup. An open and accessible design makes media loading quick and easy, and the printhead can easily be replaced without using any tools.
The ability to use any Intermec printer language and emulate other printer protocols makes the EasyCoder PD41 both fully compatible with other Intermec equipment and a cost-effective "drop-in" printer replacement in almost any non-Intermec firmware environment. Featuring full programmability (using Fingerprint), the EasyCoder PD41 can change with the application. There's no need to replace the printer when you upgrade your firmware environment - the printer will adapt.
The EasyCoder PD41 keeps your options open and protects your investment.
Intermec EasyCoder PD41 - label printer - monochrome - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
13 kg
Max Media Size
Roll (11.8 cm)
Max Media Size (Custom)
118 mm
Print Speed
Up to 150 mm/sec - max speed
Max Resolution (B&W)
203 dpi
LAN, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
Intermec Printer Language (IPL)
Media Type
Labels, continuous forms, fanfold paper, tag stock, tickets
Label Taken Sensor (LTS)
Print server - Ethernet, Fast Ethernet
AC 120/230 V
27.3 cm x 45.3 cm x 27 cm
Printer Type
Printer
Print Speed
Up to 150 mm/sec - max speed - 203 dpi
Wired
LAN, serial
203 dpi
Language Simulation
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
118 mm
Media Sizes
Roll (2.5 - 11.8 cm)
Max Printing Width
104 mm
Max Printing Length
1520 mm
Roll Maximum Outer Diameter
213 mm
Roll Core Diameter
76 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, LPR/LPD
Remote Management Protocol
SNMP 2, SNMP, HTTP
1 x RS-232 , 1 x LAN - RJ-45
UL, cUL, NOM, FCC
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
5 °C
20 - 85%
27.3 cm
45.3 cm
27 cm
13 kg
