Intermec CK71 with EX25 Scanner No Camera
Quicklinx: 9LJ5WS00 Mfr#: CK71AA4MC00W1100
The Intermec CK71 is the no-compromise, next-generation ultra-rugged mobile computer that achieves true functional agility with the perfect balance of ruggedness, duty cycle, and ergonomics for the most demanding warehouse-distribution and manufacturing environments.
Intermec CK71 - data collection terminal - Win Embedded Handheld 6.5.3 - 1 GB - 3.5"
Data collection terminal - rugged
Operating System
Microsoft Windows Embedded Handheld 6.5.3
Display
3.5" colour TFT - LED backlight - 480 x 640
Texas Instruments OMAP3715 OMAP3715
Processor Clock Speed
1 GHz
Storage
1 GB
RAM
512 MB
User Available Memory
RAM: 384 MB / Flash: 800 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g/n, Bluetooth 2.1 EDR
Rear Camera
5 Megapixel
Barcode Reader
Yes (2D imager)
8 cm x 5 cm x 23.7 cm
0.58 kg
Operating System
Display
3.5" colour TFT (transmissive) - LED backlight
Resolution
480 x 640
Colour Depth
64K colours (16-bit)
1 GHz
Storage
1 GB
RAM
512 MB
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
WEP, WPA, WPA2, 802.1x, TKIP, AES
Rear Camera
Sensor Resolution
5 Megapixel
Light Source
LED light
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, keypad
Barcodes
Barcode Reader
Scan Element Type
2D imager
Max Working Distance
15.2 m
Software
Preloaded Software
Intermec Enhanced Mobile Document Imaging (eMDI), Intermec Developer's Library (IDL), Intermec SmartSystems, VERDEX, Intermec Client Pack (ICP), Skynax Mobile Communications
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x USB
Lithium Ion
5200 mAh
Sensors
Accelerometer, ambient light sensor
FCC Class B certified, C-Tick, BSMI, DEMKO, Bluetooth Class 2, EMC, RoHS, ICES Class B, MIL-STD 810G, WEEE, IEC 60068-2-32, A-Tick, ANATEL, cULus, GOST-R, CCX V4, IP67
8 cm
5 cm
23.7 cm
0.58 kg
-20 °C
60 °C
0 - 95% (non-condensing)
Min Storage Temperature
-30 °C
Max Storage Temperature
70 °C
