The Intermec CK71 is the no-compromise, next-generation ultra-rugged mobile computer that achieves true functional agility with the perfect balance of ruggedness, duty cycle, and ergonomics for the most demanding warehouse-distribution and manufacturing environments.
- Intermec CK71 - data collection terminal - Win Embedded Handheld 6.5.3 - 1 GB - 3.5"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows Embedded Handheld 6.5.3
- Display
- 3.5" colour TFT - LED backlight - 480 x 640
- Processor
- Texas Instruments OMAP3715
- Processor Clock Speed
- 1 GHz
- Storage
- 1 GB
- RAM
- 512 MB
- User Available Memory
- RAM: 384 MB / Flash: 800 MB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 2.1 EDR
- Camera
- 5 Megapixel (rear)
- Barcode Reader
- Yes (2D imager)
- 8 cm x 5 cm x 23.7 cm
- 0.58 kg
- Product Type
- Operating System
Display
- 3.5" colour TFT (transmissive) - LED backlight
- Resolution
- 480 x 640
- Colour Depth
- 64K colours (16-bit)
- Processor
- 1 GHz
- Storage
- 1 GB
- RAM
- 512 MB
- Max Supported Capacity
- 32 GB
Communications
- WEP, WPA, WPA2, 802.1x, TKIP, AES
Camera
- Resolution (MP)
- Camera Light Source
- LED light
Multimedia
- Audio
- Microphone, speaker
Input Device
- Touch-screen, keypad
Barcodes
- Barcode Reader
- Scan Element Type
- 2D imager
- Max Working Distance
- 15.2 m
Software
- Preloaded Software
- Intermec Enhanced Mobile Document Imaging (eMDI), Intermec Developer's Library (IDL), Intermec SmartSystems, VERDEX, Intermec Client Pack (ICP), Skynax Mobile Communications
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x USB
- Technology
- Lithium Ion
- Capacity
- 5200 mAh
- Sensors
- Accelerometer, ambient light sensor
- FCC Class B certified, C-Tick, BSMI, DEMKO, Bluetooth Class 2, EMC, RoHS, ICES Class B, MIL-STD 810G, WEEE, IEC 60068-2-32, A-Tick, ANATEL, cULus, GOST-R, CCX V4, IP67
- 8 cm
- 5 cm
- 23.7 cm
- 0.58 kg
- -20 °C
- 60 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -30 °C
- Max Storage Temperature
- 70 °C
