Intel X540-T1 Bulk Ethernet Converged Network Adapter
Quicklinx: 8ZH8WS00 Mfr#: X540T1BLK
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
£118.69 ex VAT
£142.42 inc VAT
Unified networking solutions on the Intel Ethernet Converged Network Adapter X540 let you combine the traffic of multiple data center networks like LAN and SAN onto a single efficient network fabric. You now have the choice of NFS, iSCSI, or Fiber Channel over Ethernet (FCoE) to carry both network and storage traffic at speeds of up to 10 Gbps. The Intel X540 adapter combines support for all of these traffic types in one adapter at no additional cost and with no additional licensing fees for the adapter.
iSCSI uses Ethernet to carry storage traffic, extending the familiarity and simplicity of Ethernet to storage networking, without the need for SAN-specific adapters or switches. Intel Ethernet X540 is the easiest, most reliable, and most cost-effective way of connecting servers to iSCSI SANs.
  • Flexible I/O virtualization
    Virtualization changes the way server resources are deployed and managed by running multiple applications and operating systems independently on a single server.
  • Flexible Port Partitioning (FPP)
    By taking advantage of the PCI-SIG SR-IOV specification, Intel Ethernet products enable FPP. With FPP, virtual controllers can be used by the Linux host directly and/or assigned to virtual machines. FPP allows you to use the functionality of SR-IOV to assign up to 63 processes per port to virtual functions in Linux. This enables an administrator to partition their 10 GbE bandwidth across multiple processes, ensuring a QoS by giving each assigned process equal bandwidth. Network administrators may also rate-limit each of these services to control how much of the 10 GbE pipe is available to each process.
  • Unified networking
  • iSCSi simplifies SAN connectivity
Intel Ethernet Converged Network Adapter X540-T1 - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.1 x8
PCI Specification Revision
PCIe 2.1
Ports
10Gb Ethernet
Cabling Type
Ethernet 10GBase-T
10 GigE
Data Transfer Rate
10 Gbps
Network adapter
PCI Express 2.1 x8
PCIe 2.1
Ports
10Gb Ethernet
Wired
Cabling Type
Ethernet 10GBase-T
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
1 x 10GBase-T - RJ-45
Compatible Slots
1 x PCI Express 2.1 x8
Package Type
Bulk
8ZH8 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
8ZH8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
8ZH8 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.16
Compatibility: PC
Brand: Intel
Price Range Ex VAT: 100 - 150
