Intel's family of adapter, the Intel' Ethernet Converged Network Adapter X520 with SFP+ connectivity, is the flexible and scalable Ethernet adapter for today's demanding data center environments. Data center networks are being pushed to their limits. The escalating deployments of servers with multi-core processors and demanding applications such as High Performance Computing (HPC), database clusters, and video-on-demand are driving the need for 10 Gbps connections. Customers require flexible and scalable I/O solutions to meet the rigorous requirements of running mission-critical applications in virtualized and unified storage environments.
Low-profile
Enables higher bandwidth and throughput from standard and low-profile PCIe slots and servers. -
Load balancing on multiple CPUs
Increases performance on multi-processor systems by efficiently balance CPU cores when used with Receive-Side Scaling (RSS) from Microsoft or scalable I/O on Linux. -
ISCSI remote boot support
Provides centralized storage area network (SAN) management at a lower cost than other iSCSI solutions. -
Intel Direct Cache Access (DCA)
Enables the adapter to pre-fetch the data from memory, avoiding cache misses and improving application response time. -
MSI-X support
Minimizes the overhead of interrupts. Load-balancing of interrupt handling between multiple cores/CPUs. -
Low latency interrupts
Based on the sensitivity of the incoming data, the adapter can bypass the automatic moderation of time intervals between the interrupts. -
Header splits and replication in receive
Helps the driver focus on the relevant part of the packet without the need to parse it. -
IPsec offload
Offloads IPsec capability onto the adapter instead of the software to significantly improve I/O throughput and CPU usage. -
Virtual Machine Load Balancing (VLMB)
Virtual Machines Load Balancing (VMLB) provides traffic load balancing across virtual switch, port, cable, or adapter failure. -
Watchdog timer
Gives an indication to the manageability firmware or external devices that the chip or the driver is not functioning.
- Intel Ethernet Converged Network Adapter X520-DA2 - network adapter - PCIe 2.0 x8 - 10Gb Ethernet x 2
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ports
- 10Gb Ethernet x 2
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP, IPSec, iSCSI
- Processor
- Intel 82599ES
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1ae, IEEE 802.1as
- System Requirements
- Microsoft Windows 7, Linux 2.6.x, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 SP2, Microsoft Windows Vista SP2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2003 SP2, Red Hat Enterprise Linux 6, VMware ESXi, Windows 8, Microsoft Windows Server 2012, VMware ESX, Linux 3.x, FreeBSD 9
- Limited lifetime warranty
- Network adapter
- Form Factor
- Ports
- 10Gb Ethernet x 2
- Connectivity Technology
- Wired
- 10 Gigabit Ethernet
- 10 Gbps
- Remote Management Protocol
- SNMP, RMON
- Status Indicators
- Port transmission speed, link/activity
- Load balancing, VLAN support, VMDq
Processor / Memory
- Processor
- Intel 82599ES
- 2 x 10Gb Ethernet - SFP+ - x 2
- Compatible Slots
- 1 x PCI Express 2.0 x8
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS
- Package Type
- Bulk
- OS Required
- Limited warranty - lifetime
- 0 °C
- 55 °C
Intel Ethernet SFP+ Optics – SR | In Stock | £24.98 |
