PC Performance, Mobile Flexibility
Get ready for amazing. The Intel® Compute Stick is a tiny device the size of a pack of gum that can transform any HDMI TV or monitor into a complete computer. But it's what's inside that's really incredible: an Intel® Atom Quad Core processor - with blazing fast speed that gives you performance for work, play, or both -- and lets you upgrade to a world of new experience. The Intel® Compute Stick delivers everything you love about a desktop computer in a device that fits in the palm of your hand.
Connect. Compute. It's That Simple
Transform your display into a fully functional computer with the Compute Stick from Intel. This over-sized thumb drive PC offers the performance similar to your other computer and allows you to stream online videos, play games, work on projects, and more. On the inside, it sports a quad-core Intel Atom processor along with 2GB of RAM so you can simultaneously run multiple software programs. It connects to any HDMI-equipped monitor or TV and delivers high-resolution images utilizing integrated Intel HD Graphics. Additionally, it supports multi-channel audio through the same HDMI connection. For long-term storage, it is outfitted with a 32GB flash storage drive that provides instant access to your programs and data. You can expand its storage capacity by inserting an optional micro-SD card into the memory card slot, which can accept a 128GB micro-SDXC card.
This Compute Stick PC delivers full plug-and-play connectivity by offering an integrated USB 2.0 port for connecting with a printer, storage drive, or other USB devices. With built-in 802.11b/g/n Wi-Fi, it lets you wirelessly access the Internet to check emails and browse websites as well as a network for sharing files and videos. Another included wireless feature is Bluetooth 4.0 that lets you control the Stick PC with your Bluetooth keyboard and mouse from the couch in a living room or on the other side of a conference room. Bundled along with the Intel Compute Stick to ensure you stay productive are an HDMI extender cable and a 5V, 2A micro USB adapter for providing it with power.
- Intel Compute Stick - 2 GB - 32 GB
- Personal computer
- Processor
- 1 x Intel Atom x5-Z8300
- RAM
- 2 GB DDR3L SDRAM
- Hard Drive
- 1 x flash 32 GB
- Card Reader
- Graphics Controller
- Intel HD Graphics
- Networking
- 802.11b, 802.11g, 802.11n
- 3.76 cm
- 54 g
- 1 year warranty
- Personal computer
Processor / Chipset
- CPU
- Atom x5-Z8300
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
RAM
- Installed Size
- 2 GB
- Technology
- DDR3L SDRAM
Hard Drive
- Flash
- Capacity
- 1 x 32 GB
Card Reader
- Card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
Audio Output
- High Definition Audio
- Wireless LAN Supported
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power adapter
- 1 year warranty
- 3.76 cm
- 54 g
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £50.66 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
