Intel Sterling City Compute Stick Atom 2GB 32GB Windows 10
Quicklinx: C2P1WS00 Mfr#: BOXSTK1AW32SC
Processor Type: Atom x5
Operating System: Windows 10
Installed Memory: 2GB
Hard Drive Capacity: 32GB
Storage Type: Flash
  • IEEE 802.11n
Hurry, only 1 left in stock!
£96.03 ex VAT
£115.23 inc VAT
The Intel Compute Stick is a tiny device that can transform any HDMI TV or display into an entry-level computer. But it's what's inside that's really incredible: an advanced processor that gives you balanced performance for work or play. The Intel Compute Stick delivers everything you love about computing in a device that fits in the palm of your hand. Just plug the Intel Compute Stick into any HDMI TV or monitor, connect your wireless keyboard and mouse, and you're ready to roll.
And with Intel Dual Band Wireless-AC 7265 you can instantly and reliably connect and access files in the cloud, along with built-in Bluetooth 4.0 to connect to wireless peripherals or transfer files to the Compute Stick's on-board storage. With an ultimate design, this pint-sized powerhouse delivers full-size performance, reliability, and ease of use that lets you work and play when and how you want. It's ready to go out of the box, so you're ready to take your media, games, files, and power applications with you wherever you go.
Stream
Get all your favourite movies,TV shows and LIVE sport events on your TV.
Access VOD content from your most favorite platform - Amazon*, iTunes*, YouTube*, Twitch* or Netflix* in Full HD, there are no limits! Watch your favorite sport teams play LIVE on popular stream services.
Play
Play casual games or stream most demanding titles from PC or Xbox*.
With Intel Compute Stick you can play casual games in your living room. You can also stream more performance demanding game titles from your PC or Xbox*.
Surf
Get stats on your favourite player, check the latest news or find reviews for your next movie all from the comfort of your couch.
Take advantage of the full Windows computer to browse to any site on the internet with none of the restrictions found on smart TVs or streaming devices. And do it while your streaming latest movie or sporting event.
Work
Take your office with you wherever there is a display with a HDMI port.
Hot desk easily without the laptop. This tiny PC fits in the palm of your hand, delilvers fulll size performance and allows you to access cloud based data and applications. With 32GB of storage, there's even room to store your most important files.
  • With a powerful processor
    The Intel Compute Stick packs an entry-level computer into a device about the size of a pack of gum. Powered by an advanced processor, this tiny device delivers balanced performance for business-grade productivity and security. A cost-effective computer for thin client, digital signage, and PC-like embedded applications, the Intel Compute Stick allows you to make your choice for maximum flexibility to fit your usage requirements. Connectivity is quick, reliable, and seamless, with Intel wireless solutions. With two built-in antennas and Intel wireless 802.1 lac technology you can connect and access files in the cloud while using the built-in Bluetooth 4.0 to easily connect wireless peripherals or transfer files from your smartphone to the Compute Stick's on-board storage. USB 3.0 and 2.0 ports let you connect the peripherals you need such as keyboard, mouse, or an Ethernet adapter.
  • Optimized design for full performance
    Intel relentlessly develops to bring you technology that helps you meet your computing needs. The ultimate design of the Intel Compute Stick is fully optimized to maximize performance for your personal and business applications. At home or in the office, it's easier to work when, where, and how you want. The Intel Compute Stick has the quality and value you've come to expect from Intel in a product designed and built by the company itself.
Intel Compute Stick STK1AW32SC - stick - Atom x5 Z8300 1.44 GHz - 2 GB - 32 GB
Personal computer - stick
1 x Intel Atom x5 Z8300 / 1.44 GHz (1.84 GHz) (Quad-Core)
Processor Main Features
Intel Virtualization Technology, Intel AES New Instructions
Cache Memory
2 MB L3 Cache
Cache Per Processor
2 MB
RAM
2 GB (installed) / 2 GB (max) DDR3L SDRAM
Hard Drive
1 x flash 32 GB - eMMC
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics
802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Windows 10
1.2 cm x 3.8 cm x 12.3 cm
60 g
Limited warranty - 1 year
Personal computer
Product Form Factor
Stick
Processor / Chipset
CPU
Max Turbo Speed
1.84 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L3 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
2 GB / 2 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Configuration Features
Provided memory is soldered
Hard Drive
Flash - eMMC
1 x 32 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD, microSDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI
Audio Output
High Definition Audio
Wireless LAN Supported
Wireless NIC
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
1 x HDMI , 1 x USB 2.0 , 1 x USB 3.0 , 1 x PoweredUSB 2.0 - micro-USB
HDMI extension cable
Theft/Intrusion Protection
Padlock loop
ACPI
Power adapter
Operating System / Software
OS Provided
Windows 10
1.2 cm
3.8 cm
12.3 cm
60 g
35 °C
Intel Sterling City Compute Stick Atom 2GB 32GB Windows 10 Bundle deal on Intel Sterling City Compute Stick Atom 2GB 32GB Windows 10
£195.20
C2P1 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
C2P1 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.34
C2P1 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.17
C2P1 C2G 10m Select High Speed HDMI with Ethernet In Stock £40.63
C2P1 C2G 15m Select High Speed HDMI with Ethernet In Stock £55.03
C2P1 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Storage Type: Flash
Processor Model: Z8300
Type: Personal computer
Case Style: Stick
Display: no
Optical Storage: None
Brand: Intel
Price Range Ex VAT: 50 - 100
