The Intel SSD DC P3600 Series is a PCIe Gen3 SSD architected with the high performance controller interface, Non-Volatile Memory Express (NVMe), delivering leading performance, low latency, and quality of service. Matching the performance with world-class reliability and endurance, Intel SSD DC P3600 Series offers a range of capacity - 400 GB in both add-In card and 2.5-inch form factor.
With PCIe Gen3 support and NVMe queuing interface, the Intel SSD DC P3600 Series delivers excellent sequential read performance of up to 2.8 GB/s and sequential write speeds of up to 1700 MB/s. Intel SSD DC P3600 Series delivers very high random read IOPS of 450 K and random write IOPS of 70 K for 4 KB operations. Taking advantage of the direct path from the storage to the CPU by means of NVMe, Intel SSD DC P3600 Series exhibits low latency of less than 20 µs for sequential access to the SSD.
The 2.5-inch Intel SSD DC P3600 Series takes advantage of the 8639 connector and provides hot-pluggable removal and insertion providing in-service replacement options.
- Intel Solid-State Drive DC P3600 Series - SSD - 400 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 400 GB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Interface
- Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
- 1.874 cm x 16.765 cm x 6.89 cm
- 185 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 400 GB
- Interface
- 1.874 cm
- 16.765 cm
- 6.89 cm
- 185 g
Performance
- Internal Data Rate
- 2100 MBps (read) / 550 MBps (write)
- 4KB Random Read
- 320000 IOPS
- 4KB Random Write
- 30000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
- Power Consumption
- 8 Watt (write) , 7 Watt (read) , 4 Watt (idle)
- OS Required
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
- UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
- Limited warranty - 5 years
- 0 °C
- 55 °C
- 5 - 95%
