The Intel Solid-State Drive Data Center family for PCIe brings extreme data throughput directly to Intel Xeon processors with up to six times faster data transfer speed than 6 Gbps SAS/SATA SSDs. The performance of a single drive from the Intel SSD Data Center family for PCIe, specifically the Intel Solid-State Drive Data Center P3700 series (460K IOPS), can replace the performance of 7 SATA SSDs aggregated through a host bus adapter (HBA).
Breakthrough performance
The Intel Solid-State Drive Data Center family for PCIe brings extreme data throughput directly to Intel Xeon processors with up to six times faster data transfer speed than 6 Gbps SAS/SATA SSDs. The performance of a single drive from the Intel SSD Data Center family for PCIe, specifically the Intel Solid-State Drive Data Center P3700 series (460K IOPS), can replace the performance of 7 SATA SSDs aggregated through a host bus adapter (HBA). -
Modernizes data center storage
Intel led the industry in creation of a Non-Volatile Memory Express (NVMe) storage interface standard. NVMe overcomes SAS/SATA SSD performance limitations by optimizing hardware and software to take full advantage of NVM SSD technology. -
Comprehensive solution
Intel is driving transition to NVMe SSDs by providing a comprehensive product line, enabling extensive system compatibility, delivering Intel drivers as well as supporting industry driver development, and completing numerous industry standard compliance certifications. -
Proven quality and reliability
Intel SSD Data Center family for PCIe devices is based on Intel-developed controller, firmware, and leading manufacturing process NAND flash memory. Rigorous qualification and compatibility testing ensures a highly reliable SSD. The Intel SSD Data Center tool provides a powerful set of management capabilities.
- Intel Solid-State Drive DC P3700 Series - SSD - 400 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 400 GB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
- 6.985 cm x 10.045 cm x 1.5 cm
- 115 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 400 GB
- Form Factor
- 2.5"
- Interface
- 6.985 cm
- 10.045 cm
- 1.5 cm
- 115 g
Performance
- Internal Data Rate
- 2.7 GBps (read) / 1.08 GBps (write)
- 4KB Random Read
- 450000 IOPS
- 4KB Random Write
- 75000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- Compatible Bay
- 2.5"
- Power Consumption
- 18 Watt (write) , 9 Watt (read) , 4 Watt (idle)
- OS Required
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
- UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
- 0 °C
- 70 °C
- 5 - 95%
- Shock Tolerance
- 1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
- Vibration Tolerance
- 2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
