Think You Know What Small Can Do? Think Again.
Change the game with the Intel NUC Kit NUC6i7KYK. A Mini PC with the 6th generation Intel Core i7 processor and Intel Iris Pro Graphics, the NUC6i7KYK unleashes maximized performance for intense game play or intensive workloads. With an amazing new lid, along with a redesigned chassis that lets you take full advantage of every GHz of the quad-core processor without overheating—the NUC6i7KYK is totally cool. Literally.
Whether you use the NUC to train your dragon or bring down your enemy's nexus, or to visualize complex information like Monte Carlo simulations, you've got the performance you need, including 30x better 3D graphics, for higher resolution and faster frame rates. And with Thunderbolt 3 you get four times the data and twice the video bandwidth of any other cable—which means you have blazing fast throughput for an external RAID stack or an external graphics engine.
Work and Play in High Resolution with Intel Iris Pro Graphics
Intel Iris Pro Graphics with 4K display capabilities let you edit photos and videos like a professional or immerse yourself in vividly rendered, seamless 3D gameplay, All in brilliant 4K on three monitors at once. When you use Intel Iris Pro graphics, you're working smarter, playing harder, and seeing the whole world in high resolution knowing you are using the best Intel Core processors. You've got the best processor graphics with enhanced media conversion and fast frame that delivers picture perfect performance, every time.
Designed for Windows 10, so you can get more done
The Intel NUC is designed for Windows 10. You'll experience cutting-edge performance from the start with fast boot and wake-up times, and multitasking that's effortless whether moving between apps, files, or web sites. With support for up to 32 GB of RAM, you can get the memory you need for fast map load times or extreme multitasking. And with 4 USB 3.0 ports including a USB charging port, you can use a USB keyboard, mouse, and an Intel RealSense camera so you can video chat and collaborate with others as easily as if you were in the same room.
Cut the cords, not the performance
The NUC6i7KYK comes with Intel 802.11ac wireless, Intel's fastest wireless available today, so you can connect out-of-the-box and access files, movies, and music in the cloud, along with built-in Bluetooth 4.2 so you can connect wireless peripherals like headsets and keyboards.
Intel NUC: Change The Game
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit NUC6i7KYK - mini PC - Core i7 6770HQ 2.6 GHz - 0 GB - no HDD - UK power cord
- PC barebone - mini PC
- Processor
- 1 x Intel Core i7 (6th Gen) 6770HQ / 2.6 GHz (, up to 3.5 GHz, (Quad-Core)
- Processor Main Features
- Intel Virtualization Technology, Intel AES New Instructions
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel Iris Pro Graphics 580
- Audio Output
- 7.1 channel surround
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- 21.1 cm x 11.6 cm x 2.8 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6770HQ
- Clock Speed
- 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 2 x SATA
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SDXC UHS-I Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- High Definition Audio
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Intel Wireless Display (WiDi)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Bays
- 2 (total) / 2 (free) x internal M.2 2242/2280
- Slots
- 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 3.0 (2 internal) , 2 x USB 2.0 (2 internal) , 1 x USB-C (1 rear) , 1 x HDMI , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x Mini DisplayPort , 1 x headphones/microphone - mini-jack (1 in front) , 1 x TOSLINK - mini-jack (1 rear)
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Plug and Play, ETSI, EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, VCCI V-3, EN 62311, VCCI V-4, KN22, KN24, China RoHS, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301489-17, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- Power adapter
- Power Provided
- 120 Watt
- 21.1 cm
- 11.6 cm
- 2.8 cm
- 0 °C
- 40 °C
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black | In Stock | £16.31 |
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black | In Stock | £17.40 |
