Intel Skull Canyon NUC Intel Core i7-6770HQ DDR4 M.2 Iris Pro Graphics Barebone PC
Quicklinx: C32HWS00 Mfr#: BOXNUC6I7KYK3
  • Core i7
  • IEEE 802.11n
10 in stock
£432.98 ex VAT
£519.57 inc VAT
Think You Know What Small Can Do? Think Again.
Change the game with the Intel NUC Kit NUC6i7KYK. A Mini PC with the 6th generation Intel Core i7 processor and Intel Iris Pro Graphics, the NUC6i7KYK unleashes maximized performance for intense game play or intensive workloads. With an amazing new lid, along with a redesigned chassis that lets you take full advantage of every GHz of the quad-core processor without overheating—the NUC6i7KYK is totally cool. Literally.
Whether you use the NUC to train your dragon or bring down your enemy's nexus, or to visualize complex information like Monte Carlo simulations, you've got the performance you need, including 30x better 3D graphics, for higher resolution and faster frame rates. And with Thunderbolt 3 you get four times the data and twice the video bandwidth of any other cable—which means you have blazing fast throughput for an external RAID stack or an external graphics engine.
Work and Play in High Resolution with Intel Iris Pro Graphics
Intel Iris Pro Graphics with 4K display capabilities let you edit photos and videos like a professional or immerse yourself in vividly rendered, seamless 3D gameplay, All in brilliant 4K on three monitors at once. When you use Intel Iris Pro graphics, you're working smarter, playing harder, and seeing the whole world in high resolution knowing you are using the best Intel Core processors. You've got the best processor graphics with enhanced media conversion and fast frame that delivers picture perfect performance, every time.
Designed for Windows 10, so you can get more done
The Intel NUC is designed for Windows 10. You'll experience cutting-edge performance from the start with fast boot and wake-up times, and multitasking that's effortless whether moving between apps, files, or web sites. With support for up to 32 GB of RAM, you can get the memory you need for fast map load times or extreme multitasking. And with 4 USB 3.0 ports including a USB charging port, you can use a USB keyboard, mouse, and an Intel RealSense camera so you can video chat and collaborate with others as easily as if you were in the same room.
Cut the cords, not the performance
The NUC6i7KYK comes with Intel 802.11ac wireless, Intel's fastest wireless available today, so you can connect out-of-the-box and access files, movies, and music in the cloud, along with built-in Bluetooth 4.2 so you can connect wireless peripherals like headsets and keyboards.
Intel NUC: Change The Game
  • Superior processing and graphics
    Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics.
  • Stunningly small form factor
    The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations.
  • Advanced technology
    The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
Intel Next Unit of Computing Kit NUC6i7KYK - mini PC - Core i7 6770HQ 2.6 GHz - 0 GB - UK power cord
PC barebone - mini PC
1 x Intel Core i7 (6th Gen) 6770HQ / 2.6 GHz (3.5 GHz) (Quad-Core)
Processor Main Features
Intel Virtualization Technology, Intel AES New Instructions
Cache Memory
6 MB L3 Cache
Cache Per Processor
6 MB
RAM
0 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel Iris Pro Graphics 580
Audio Output
7.1 channel surround
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
21.1 cm x 11.6 cm x 2.8 cm
Limited warranty - 3 years
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L3 Cache - 6 MB
Cache Per Processor
6 MB
RAM
Installed Size
0 GB / 32 GB (max)
DDR4 SDRAM
SO-DIMM 260-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Storage Controller
2 x SATA
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
3
Audio Output
Sound Output Mode
High Definition Audio
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Intel Wireless Display (WiDi)
Bays
2 (total) / 2 (free) x internal M.2 2242/2280
Slots
2 (total) / 2 (free) x SO-DIMM 260-pin
4 x USB 3.0 (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 3.0 (2 internal) , 2 x USB 2.0 (2 internal) , 1 x USB-C (1 rear) , 1 x HDMI , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x Mini DisplayPort , 1 x headphones/microphone - mini-jack (1 in front) , 1 x TOSLINK - mini-jack (1 rear)
VESA mounting kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Plug and Play, ETSI, EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, VCCI V-3, EN 62311, VCCI V-4, KN22, KN24, China RoHS, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301489-17, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
Power adapter
Power Provided
120 Watt
21.1 cm
11.6 cm
2.8 cm
Intel Skull Canyon NUC Intel Core i7-6770HQ DDR4 M.2 Iris Pro Graphics Barebone PC Bundle deal on Intel Skull Canyon NUC Intel Core i7-6770HQ DDR4 M.2 Iris Pro Graphics Barebone PC
£615.99
saving £8.33
£532.15
C32H C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - White In Stock £11.88
C32H C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - Black In Stock £6.45
C32H C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter Cable - Black In Stock £7.95
C32H C2G 20cm Mini DisplayPort Male to Single Link DVI-D Female Adapter Cable - White In Stock £10.62
C32H C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black In Stock £14.97
C32H C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £15.75
Brand: Intel
Price Range Ex VAT: 300 - 500
