Built for compatibility in legacy infrastructures, this SATA SSD enables easy storage upgrades that minimize the costs associated with modernizing your data center.
Based on TLC Intel 3D NAND Technology, these larger capacity SSDs enable data centers to increase data stored per rack unit. Realize the performance benefits SSDs provide over HDDs, without expanding the server footprint.
With 3.2x lower Annualized Failure Rate (AFR) compared to HDDs, IT departments will spend less time and expense replacing or upgrading storage devices. Intel SATA SSDs install seamlessly and complete updates without reset, reducing downtime.
Infrastructure compatibility
Built for compatibility in legacy infrastructures, this SATA SSD enables easy storage upgrades that minimize the costs associated with modernizing your data center. -
Do more per server
Based on TLC Intel 3D NAND Technology, these larger capacity SSDs enable data centers to increase data stored per rack unit. Realize the performance benefits SSDs provide over HDDs, without expanding the server footprint. -
Improved reliability
With 3.2x lower Annualized Failure Rate (AFR) compared to HDDs, IT departments will spend less time and expense replacing or upgrading storage devices. Intel SATA SSDs install seamlessly and complete updates without reset, reducing downtime. -
Good SATA controller
A SATA-designed controller delivers the convergence of scalable capacity and manageability. Innovative firmware completes updates without server reset and reduces downtime.
- Intel Solid-State Drive DC S4500 Series - SSD - 1.9 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1.9 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Temperature sensor, Native Command Queuing (NCQ), SMART Command Transport (SCT), Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection, Windows WHCK certified, 3D NAND Technology, S.M.A.R.T.
- 69.85 mm x 100.45 mm x 7 mm
- 66 g
- 5-year warranty
- Capacity
- 1.9 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.45 mm
- 7 mm
- 66 g
Performance
- SSD Endurance
- 3.27 PB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 490 MBps (write)
- 4KB Random Read
- 72000 IOPS
- 4KB Random Write
- 33000 IOPS
- Average Latency
- 36 µs
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 5 Watt (active) , 1 Watt (idle)
- UL, VCCI, C-Tick, BSMI, ICES-003, FCC Part 15 B, RoHS, KCC, WEEE, EN 60950-1 Second Edition, EN55022:2006, SATA-IO, EN55024:1998, CAN/CSA-CEI/IEC CISPR 22:02, WHCK
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95%
- Shock Tolerance (operating)
- 1000 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1000 g @ 0.5 ms
- Vibration Tolerance (operating)
- 2.17 g @ 5-700 Hz
- Vibration Tolerance (non-operating)
- 3.13 g @ 5-800 Hz
