The Intel Solid-State Drive Data Center family for SATA expands with the Intel SSD DC S3610 series. The Intel SSD DC S3610 series offers the next generation of data center SSDs optimized for mixed read-write performance, endurance, and strong data protection.
The Intel SSD DC S3610 series accelerates data center performance with read/write throughput speeds up to 550/5201 megabytes per second(MB/s)and 4K random read/write input/output operations per second(IOPs)up to 84,000/28,0001. Applications benefit from 55 µs typical latency with max read latencies2 of 500 µs 99.9 percent3 of the time. Combining performance with low typical active power the Intel SSD DC S3610 series improves data center efficiency with superior quality of service and reduced energy costs.
High reliability - low total cost of ownership
Intel SSDs are known industry wide for quality and reliability. The Intel SSD DC Family for SATA is engineered to reduce downtime as a result of storage-related failures and designed to meet an Annualized Failure Rate(AFR)2 of 0.44%. The Intel SSD DC Family for SATA significantly reduces Total Cost of Ownership(TCO). -
Power-efficient performance
The Intel SSD DC Family for SATA accelerates data center performance with read-write throughput speeds up to 550/5201 megabytes per second(MB/s)and 4K random read-write input/output operations per second(IOPs)up to 85,000/45,0001. Applications benefit from 55 µs typical latency with max read latencies4 of 500 µs 99.9% of the time. Combining performance with low typical active power, the Intel SSD DC Family for SATA improves data center efficiency with superior quality of service, reduced energy costs, and is ideal for server or application upgrades. -
Stress-free data protection
All of the products in the Intel SSD DC Family for SATA protect data with full end-to-end dataprotection, 256-bit encryption Advanced Encryption Standard(AES)technology, sophisticated error protection schemes, andenhanced power loss and thermal monitoring features.
- Intel Solid-State Drive DC S3510 Series - SSD - 1.2 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1.2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 16nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Native Command Queuing (NCQ), TRIM support, Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, Thermal throttling, End-to-end data protection, Windows WHCK certified, Hot-Plug Support, S.M.A.R.T.
- 69.85 mm x 100.45 mm x 7 mm
- 94 g
- 5-year warranty
- Capacity
- 1.2 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.45 mm
- 7 mm
- 94 g
Performance
- SSD Endurance
- 660 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 440 MBps (write)
- 4KB Random Read
- 67000 IOPS
- 4KB Random Write
- 20000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 5.24 Watt (active) , 0.7 Watt (idle)
- OS Required
- Microsoft Windows Server 2003 R2 Enterprise x64 Edition SP2, Microsoft Windows Server 2008 R2 SP1, Microsoft Windows Server 2008 (32/64-bits) SP2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1, Red Hat Enterprise Linux 5.5 - 7.0, CentOS 6.3 (64-bit), CentOS 5.7 (64-bit)
- UL, VCCI, C-Tick, BSMI, FCC Part 15 B, RoHS, UL 60950-1 Second Edition, KCC, WEEE, EN 60950-1 Second Edition, SATA-IO, EN55024:1998, CAN/CSA-CEI/IEC CISPR 22:02
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95%
- Shock Tolerance (operating)
- 1000 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1000 g @ 0.5 ms
- Vibration Tolerance (operating)
- 2.17 g @ 5-700 Hz
- Vibration Tolerance (non-operating)
- 3.13 g @ 5-800 Hz
