Product
Brand
Intel RAID Smart Battery
Quicklinx: 6ZTVWS00 Mfr#: AXXRSBBU6
The Intel RAID Smart Battery (RSB) is a small battery pack accessory to the Intel Integrated Server RAID and the SCSI RAID on Motherboard (ROMB) solutions used on particular Intel Server Platforms. The Smart Battery preserves the contents of the RAID DIMM in the event of a power failure. Once power is restored, all of the preserved data in the RAID Cache DIMM is flushed to the RAID drives. The Smart Battery Circuit ensures that the backup battery is maintained at a full charge for optimal performance when it is activated. When activated, it provides backup power to the RAID DIMM for up to 64 hours.
Intel RAID Smart Battery - memory backup battery - Li-Ion - 700 mAh
Memory backup battery
40 g
Lithium Ion - 700 mAh
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
72 hours
6.6 cm x 5.4 cm
RAID Controller SRCSASBB8I, SRCSASLS4I
Battery Enclosure Type
Internal
Quantity
1
Lithium Ion
Voltage Provided
3.7 V
700 mAh
Run Time (Up To)
72 hrs
Recharge Time
8 hours
Max Recharge Cycles
500
MTBF
2,490,772 hours
10 °C
45 °C
20 - 80%
6.6 cm
5.4 cm
40 g
Intel RAID Controller SRCSASBB8I, SRCSASLS4I
