Intel PRO/1000 PT Dual Port Server
Quicklinx: 7ZWRWS00 Mfr#: EXPI9402PTBLK
Conserve valuable PCI Express (PCIe) server slots while adding multi-port Gigabit Ethernet capability with the Intel PRO/1000 PT Dual Port Server Adapter. The dedicated input/output (I/O) bandwidth of PCIe ensures priority performance on each port - without bus sharing - for Gigabit Ethernet connectivity in Category-5 networks. Additionally, the Intel PRO/1000 PT Dual Port Server Adapter is designed to provide high performance in multi-processor systems by efficiently balancing network loads across multiple Central Processing Units (CPUs) when used with Receive-Side Scaling from Microsoft or Scalable I/O on Linux.
Intel PRO/1000 PT Dual Port Server Adapter - It just works!
Intel PRO/1000 PT Dual Port Server Adapter - network adapter - PCIe x4 - Gigabit Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.0a
Ports
2.2 cm x 12.9 cm x 12 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Intel 82571GB
IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), WfM 2.0
SCO OpenServer 5, Microsoft Windows 2000, Novell NetWare 5.x, SunSoft Solaris x86 8, Novell NetWare 6.x, Caldera OpenUnix 8, Linux 2.4 or later, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Datacenter Edition, FreeBSD 4.x
Microsoft Certification
Compatible with Windows 7
Network adapter
Plug-in card
PCI Express x4
PCIe 1.0a
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP, DMI 2.0
Status Indicators
Port transmission speed, link OK
Full duplex capability, ACPI support, auto-negotiation, wake on LAN (WOL), Intel I/O Acceleration Technology (I/OAT)
Processor / Memory
Intel 82571GB
2 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x4
FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC, RoHS
Package Type
Bulk
Software Included
Intel PROSet
2.2 cm
12.9 cm
12 cm
Limited warranty - lifetime
55 °C
7ZWR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
