The Intel SSD DC P3100 Series delivers ideal endurance and performance for very read-intensive workloads in the data center. With the space-saving advantages delivered by the M.2 form factor and the drive's superior power efficiency, data centers can expect to see total cost of ownership benefits with the DC P3100.
- Intel Solid-State Drive DC P3100 Series - SSD - 256 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 256 GB
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- M.2 2280
- Interface
- Read Unrecoverable Bit Error Rate (UBER) 10e-15, 256-bit AES
- 22 mm x 80 mm
- 10 g
- 5-year warranty
- Capacity
- 256 GB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 10 g
Performance
- Internal Data Rate
- 1400 MBps (read) / 100 MBps (write)
- 4KB Random Read
- 52500 IOPS
- 4KB Random Write
- 5500 IOPS
Reliability
- MTBF
- 1,600,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe)
- Compatible Bay
- M.2 2280
- Power Consumption
- 4 Watt (active) , 0.5 Watt (idle)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1000 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1000 g @ 0.5 ms
- Vibration Tolerance (operating)
- 2.17 g @ 5-700 Hz
- Vibration Tolerance (non-operating)
- 3.13 g @ 5-800 Hz
