Intel NUC NUC7I3DNK3E Intel Core i3-7100U Dawson Canyon mini PC
Quicklinx: D8Z4WS00 Mfr#: BLKNUC7I3DNK3E
  • Core i3
  • IEEE 802.11n
10 in stock
£167.53 ex VAT
£201.03 inc VAT
No more compromising between performance, profile, and value. The NUC is a tiny computing device with the power of advanced processor. Its lower power consumption enables innovative system designs and energy-efficient applications in places like digital signage, home entertainment, and portable uses.
  • Superior processing and graphics
    Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics.
  • Stunningly small form factor
    The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations.
  • Advanced technology
    The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
Intel Next Unit of Computing Kit NUC7i3DNKE - mini PC - Core i3 7100U 2.4 GHz - 0 GB
PC barebone - mini PC
1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel 64 Technology, Intel AES New Instructions
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 GB (installed) / 32 GB (max) DDR4 SDRAM
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 620
Audio Output
7.1 channel surround
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
11.5 cm x 11.1 cm x 3.6 cm
Limited warranty - 3 years
PC barebone
Product Form Factor
Mini PC
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 GB / 32 GB (max)
DDR4 SDRAM
Rated Memory Speed
2133 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Audio Output
Sound Output Mode
High Definition Audio
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 1 (free) x internal M.2 2280 , 1 (total) / 0 (free) x internal M.2 2230
Slots
2 (total) / 2 (free) x SO-DIMM 260-pin
4 x USB 3.0 - Type A (2 front, 2 rear) , 2 x USB 2.0 (2 internal) , 1 x USB 3.0 (1 internal) , 2 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial - DB-9
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Plug and Play, ICES-003, EN55024, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, KN24, China RoHS, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301 489-1, EN 300 893, CISPR32/EN55032, KN32, AS/NZS 2772.2, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
Power adapter
Power Provided
65 Watt
11.5 cm
11.1 cm
3.6 cm
Brand: Intel
Price Range Ex VAT: 150 - 300
