The 4-inch square Intel NUC NUC5i3RYH takes the powerful capabilities of a desktop system and packages it into a computer that fits in the palm of your hand. This fully scalable system comes with 5th generation Intel Core i3 processor and integrated Intel HD Graphics with 4K display support. Whether you want a digital jukebox, home hub, or light gaming PC, the Intel NUC NUC5i3RYH gives you the power to play, create, entertain, and inspire. The system includes consumer infrared sensor so you can use a remote control for your NUC right from your couch, 7.1 surround sound, Mini HDMI video interface, and room for a 2.5" HDD or an M.2 SSD so you can store full-length movies or quickly serve up music files. With Intel WiDi you can connect your monitor without any additional cables and Bluetooth lets you place wireless speakers where you want - all the features you want in a space-saving, clutter-free design. There's also a high-speed USB 3.0 charging port that lets you easily charge your tablet or smartphone quickly. And for peace of mind you'll get embedded security that helps keep threats out, user identities and credentials safe, and your data protected.
- Built in Intel Core i3 Dual Core Processor
- Intel HD Graphics 5500 with Mini HDMI & Mini DisplayPort Outputs
- Up to 7.1 surround sound via Mini HDMI & Mini DisplayPort
- Wireless-AC M.2 Card with Bluetooth 4.0
- Gigabit Ethernet
- 4x USB 3.0 Ports
- VESA Mount Support
- Super Compact Form Factor
- Supports up to 16GB of Low Voltage DDR3L Memory (Not Included, Sold Separately)
- Supports 1x M.2 22x42, 22x60, or 22x80 SSD Card(Not Included, Sold Separately)
- Supports 1x 2.5" SATA 3 HDD/SSD up to 9.5mm thickness(Not Included, Sold Separately)
- Certified OS: Windows 8 & 8.1 (Not Included, Sold Separately)
- Compatible OS: Ubuntu, Linux Mint, Fedora, OpenSUSE (Not Included)
Note: Barebone NUCs accept Low Voltage 1.35v DDR3L SO-DIMM Modules ONLY.
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit NUC5i3RYH - mini PC - Core i3 5010U 2.1 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Core i3 (5th Gen) 5010U / 2.1 GHz (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Wireless Display, Intel 64 Technology
- Cache Memory
- 3 MB L3 Cache
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Audio Output
- 7.1 channel surround - integrated
- Networking
- GigE, 802.11b/g/n, 802.11ac
- OS Provided
- No operating system
- Silver aluminium ring with diamond cut around black top
- 11.5 cm x 11.1 cm x 4.87 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5010U / 2.1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L3 Cache - 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Type M
- 2 x USB 2.0 (2 internal) , 1 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 2 x SATA-600 (2 internal)
- Included Accessories
- VESA mounting kit
- Voltage monitoring, temperature sensor, automatic fan speed control, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel Smart Response Technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- EN55022, ICES-003, EN55024, CISPR 22, FCC Part 15 B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC Part 15 A, VCCI V-3, VCCI V-4, KN22, KN24, CAN/CSA-C22.2 No. 60950-1
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 11.5 cm
- 11.1 cm
- 4.87 cm
- 0 °C
- 55 °C
C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black | In Stock | £14.42 |
C2G 2m Mini DisplayPort Cable M/M - White | In Stock | £10.83 |
