Intel NUC Kit Rock Canyon, UCFF, Core i3 5010U 2.1 GHz, DDR3L, M.2 / 2.5" SATA 6Gb/s
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: B32PWS00 Mfr#: BOXNUC5i3RYH
  • Core i3
  • IEEE 802.11n
The 4-inch square Intel NUC NUC5i3RYH takes the powerful capabilities of a desktop system and packages it into a computer that fits in the palm of your hand. This fully scalable system comes with 5th generation Intel Core i3 processor and integrated Intel HD Graphics with 4K display support. Whether you want a digital jukebox, home hub, or light gaming PC, the Intel NUC NUC5i3RYH gives you the power to play, create, entertain, and inspire. The system includes consumer infrared sensor so you can use a remote control for your NUC right from your couch, 7.1 surround sound, Mini HDMI video interface, and room for a 2.5" HDD or an M.2 SSD so you can store full-length movies or quickly serve up music files. With Intel WiDi you can connect your monitor without any additional cables and Bluetooth lets you place wireless speakers where you want - all the features you want in a space-saving, clutter-free design. There's also a high-speed USB 3.0 charging port that lets you easily charge your tablet or smartphone quickly. And for peace of mind you'll get embedded security that helps keep threats out, user identities and credentials safe, and your data protected.
  • Built in Intel Core i3 Dual Core Processor
  • Intel HD Graphics 5500 with Mini HDMI & Mini DisplayPort Outputs
  • Up to 7.1 surround sound via Mini HDMI & Mini DisplayPort
  • Wireless-AC M.2 Card with Bluetooth 4.0
  • Gigabit Ethernet
  • 4x USB 3.0 Ports
  • VESA Mount Support
  • Super Compact Form Factor
  • Supports up to 16GB of Low Voltage DDR3L Memory (Not Included, Sold Separately)
  • Supports 1x M.2 22x42, 22x60, or 22x80 SSD Card(Not Included, Sold Separately)
  • Supports 1x 2.5" SATA 3 HDD/SSD up to 9.5mm thickness(Not Included, Sold Separately)
  • Certified OS: Windows 8 & 8.1 (Not Included, Sold Separately)
  • Compatible OS: Ubuntu, Linux Mint, Fedora, OpenSUSE (Not Included)
Note: Barebone NUCs accept Low Voltage 1.35v DDR3L SO-DIMM Modules ONLY.
  • Superior processing and graphics
    Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics.
  • Stunningly small form factor
    The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations.
  • Advanced technology
    The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
Intel Next Unit of Computing Kit NUC5i3RYH - mini PC - Core i3 5010U 2.1 GHz - 0 MB
PC barebone - mini PC
1 x Intel Core i3 (5th Gen) 5010U / 2.1 GHz (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Wireless Display, Intel 64 Technology
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
0 MB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Audio Output
7.1 channel surround - integrated
GigE, 802.11b/g/n, 802.11ac
OS Provided
No operating system
Silver aluminium ring with diamond cut around black top
11.5 cm x 11.1 cm x 4.87 cm
Limited warranty - 3 years
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 MB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Storage Controller
SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Type M
2 x USB 2.0 (2 internal) , 1 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 2 x SATA-600 (2 internal)
VESA mounting kit
Voltage monitoring, temperature sensor, automatic fan speed control, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel Smart Response Technology
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EN55022, ICES-003, EN55024, CISPR 22, FCC Part 15 B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC Part 15 A, CAN/CSA C22.2 No. 60950-1, VCCI V-3, VCCI V-4, KN22, KN24
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
No operating system
11.5 cm
11.1 cm
4.87 cm
55 °C
B32P C2G 2M Value Series™ High Speed with Ethernet HDMI® Mini Cable In Stock £6.55
B32P C2G 1M Value Series™ High Speed with Ethernet HDMI® Mini Cable In Stock £6.00
B32P C2G 3m Value Series™ High Speed with Ethernet HDMI® Mini Cable In Stock £7.50
B32P C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black In Stock £24.12
B32P C2G 2m Mini DisplayPort Cable M/M - White In Stock £12.48
B32P C2G HDMI Mini to HDMI Adapter Converter In Stock £8.68
