Product
Intel NUC Kit Rock Canyon, UCFF, Core i3 5010U / 2.1 GHz, DDR3L, M.2, Intel HD 5500
Quicklinx: B32NWS00 Mfr#: BOXNUC5i3RYK
  • Core i3
  • Bluetooth 4.0
  • IEEE 802.11n
The 4-inch square Intel NUC NUC5i3RYK takes the powerful capabilities of a desktop system and packages it into a computer that fits in the palm of your hand. This fully scalable system comes with 5th generation Intel Core i3 processor and integrated Intel HD Graphics with 4K display support. Whether you want a digital jukebox, home hub, or light gaming PC, the Intel NUC NUC5i3RYK gives you the power to play, create, entertain, and inspire. The system is designed to hold a lightning fast and compact M. 2 SSD so you can quickly stream music or movie files, and also features consumer infrared and a Mini HDMI video interface. With Intel WiDi you can connect your monitor without any additional cables and Bluetooth lets you place wireless speakers where you want - all the features you want in a space-saving, clutter-free design. A replaceable lid gives you plenty of options to create the NUC you want - with amazing style and features. There's also a high-speed USB 3.0 charging port that lets you easily charge your tablet or smartphone quickly. And for peace of mind you'll get embedded security that helps keep threats out, user identities and credentials safe, and your data protected.
  • Superior processing and graphics
    Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics.
  • Stunningly small form factor
    The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations.
  • Advanced technology
    The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
Intel Next Unit of Computing Kit NUC5i3RYK - mini PC - Core i3 5010U 2.1 GHz - 0 MB
PC barebone - mini PC
1 x Intel Core i3 (5th Gen) 5010U / 2.1 GHz (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Wireless Display, Intel 64 Technology, Intel AES New Instructions
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
0 MB (installed) / 16 GB (max) - DDR3L SDRAM
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 5500
Audio Output
7.1 channel surround - integrated
GigE, 802.11b, 802.11a, 802.11g, 802.11n, Bluetooth 4.0, 802.11ac
OS Provided
No operating system
11.5 cm x 11.1 cm x 3.45 cm
Limited warranty - 3 years
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 MB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Storage Controller
Integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
ACPI support, Intel Wireless Display (WiDi)
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Card
4 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x USB 2.0 (2 internal) , 2 x SATA-600 (2 internal)
Voltage monitoring, temperature sensor, Intel Rapid Start Technology, MIMO technology, Intel Rapid Storage Technology, 1 USB 3.0 charging port, fan speed controller, built-in infrared sensor, Intel Ready Mode Technology
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EN55022, ICES-003, EN55024, CISPR 22, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, CAN/CSA C22.2 No. 60950-1, VCCI V-3, VCCI V-4, KN22, KN24, China RoHS, CNS 13438, RoHS 2011/65/EU, WEEE 2002/96/EC
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
No operating system
11.5 cm
11.1 cm
3.45 cm
50 °C
B32N C2G 2M Value Series™ High Speed with Ethernet HDMI® Mini Cable In Stock £6.48
B32N C2G 1M Value Series™ High Speed with Ethernet HDMI® Mini Cable In Stock £5.94
B32N C2G 3m Value Series™ High Speed with Ethernet HDMI® Mini Cable In Stock £7.50
B32N C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black In Stock £23.82
B32N C2G 2m Mini DisplayPort Cable M/M - White In Stock £12.32
B32N C2G HDMI Mini to HDMI Adapter Converter In Stock £8.55
