Equipped with a 5th generation Intel Core i7-5557U processor, NUC5i7RYH is the highest performing Intel NUC ever. Iris graphics 6100 delivers amazing multimedia experiences and makes NUC5i7RYH perfect for immersive gaming. A replaceable lid provides plenty of options to extend system capabilities or add personal style. Intel turbo boost technology 2.01 delivers performance that adapts to your needs. Complete with Wi-Fi 802.11ac wireless, Bluetooth, and 7.1 surround sound, NUC5i7RYH is ideal for home theater PCs, media server PCs, and home hubs.
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit NUC5I7RYH - mini PC - Core i7 5557U 3.1 GHz - 0 GB - no HDD
- PC barebone - mini PC - Intel Rapid Start Technology, 1 USB 3.0 charging port, Intel Ready Mode Technology
- Processor
- 1 x Intel Core i7 (5th Gen) 5557U / 3.1 GHz (, up to 3.4 GHz, (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Wireless Display, Intel 64 Technology
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel Iris Graphics 6100
- Audio Output
- 7.1 channel surround - integrated
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- No operating system
- Silver with black top and diamond cut around the top
- 11.5 cm x 11.1 cm x 4.87 cm
- Limited warranty - replacement - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i7 (5th Gen) 5557U
- Clock Speed
- 3.1 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture, low-voltage
Hard Drive
- No HDD
Storage Controller
- SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- ACPI support, Intel Wireless Display (WiDi)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin (1.35 V) , 1 (total) / 1 (free) x M.2 Card
- 4 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x SATA-600 (2 internal)
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- EN55022, ICES-003, EN55024, CISPR 22, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, ACPI 3.0b, VCCI V-3, VCCI V-4, KN22, KN24, China RoHS, CNS 13438, RoHS 2011/65/EU, WEEE 2002/96/EC, CAN/CSA-C22.2 No. 60950-1
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 11.5 cm
- 11.1 cm
- 4.87 cm
