Get ready for truly immersive entertainment. The Intel® NUC Kit NUC7i3BNH is built with a dual-core 7th Generation Intel® Core™ i3 processor. So whether you’re streaming the latest movie or need to finish that last minute presentation, you’ve got the performance to handle it with ease. With dual-array front microphones, you can take full advantage of Windows® 10 and Cortana. Now you’ve got your own digital personal assistant to keep you on time to appointments, help you send email, or find that new recipe. Intel® NUC Kit NUC7i3BNH also supports 4K at 60 Hz via an HDMI 2.0 port. A multi-color LED ring lets you personalize your NUC with the look you want. Also features a 2.5" drive bay for an SSD or HDD with up to 2 TB of storage.
Customized computing
The Intel NUC includes a customizable board and chassis that are ready to accept the memory, hard drive, and operating system of your choice. -
Home entertainment
With a full-sized HDMI port, turn your Intel NUC into a complete home entertainment system. -
Pint-sized power
The Intel NUC is a Mini PC with the power of a desktop, packing features for entertainment, gaming, and productivity in a small form factor. -
Energy optimized, media savvy
With Intel NUC you get an immersive media experience and responsive interaction while consuming a small amount of power relative to a full-sized PC. -
Flexibility for future growth
Due to its portable size and ease of installation, the Intel NUC makes it easy to add devices and scale up rapidly based on changing productivity needs.
- Intel Next Unit of Computing Kit NUC7i3BNH - mini PC - Core i3 7100U 2.4 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel 64 Technology, Intel AES New Instructions
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s) M.2 Card
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel HD Graphics 620
- Audio Output
- 7.1 channel surround
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- 11.5 cm x 11.1 cm x 5.1 cm
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U
- Clock Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Storage Controller (2nd)
- - M.2 Card
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SDXC UHS-I Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 1 (total) / 1 (free) x internal M.2 2242/2280
- Slots
- 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 - Type A (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort/USB-C 3.1 Gen 2 , 2 x SATA-600 (2 internal)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Plug and Play, ICES-003, EN55024, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, KN24, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301 489-1, EN 300 893, CISPR32/EN55032, KN32, AS/NZS 2772.2, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- Power adapter
- Power Provided
- 65 Watt
- 11.5 cm
- 11.1 cm
- 5.1 cm
- 0 °C
- 40 °C
