Intel NUC Baby Canyon Core i3-7100U DDR4 M.2 PCIe USB3.1 Barebone
Quicklinx: CQ47WS00 Mfr#: BOXNUC7i3BNH
  • Core i3
  • IEEE 802.11n
16 in stock
£214.10 ex VAT
£256.92 inc VAT
Get ready for truly immersive entertainment. The Intel® NUC Kit NUC7i3BNH is built with a dual-core 7th Generation Intel® Core™ i3 processor. So whether you’re streaming the latest movie or need to finish that last minute presentation, you’ve got the performance to handle it with ease. With dual-array front microphones, you can take full advantage of Windows® 10 and Cortana. Now you’ve got your own digital personal assistant to keep you on time to appointments, help you send email, or find that new recipe. Intel® NUC Kit NUC7i3BNH also supports 4K at 60 Hz via an HDMI 2.0 port. A multi-color LED ring lets you personalize your NUC with the look you want. Also features a 2.5" drive bay for an SSD or HDD with up to 2 TB of storage.
  • Customized computing
    The Intel NUC includes a customizable board and chassis that are ready to accept the memory, hard drive, and operating system of your choice.
  • Home entertainment
    With a full-sized HDMI port, turn your Intel NUC into a complete home entertainment system.
  • Pint-sized power
    The Intel NUC is a Mini PC with the power of a desktop, packing features for entertainment, gaming, and productivity in a small form factor.
  • Energy optimized, media savvy
    With Intel NUC you get an immersive media experience and responsive interaction while consuming a small amount of power relative to a full-sized PC.
  • Flexibility for future growth
    Due to its portable size and ease of installation, the Intel NUC makes it easy to add devices and scale up rapidly based on changing productivity needs.
Intel Next Unit of Computing Kit NUC7i3BNH - mini PC - Core i3 7100U 2.4 GHz - 0 GB
PC barebone - mini PC
1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel 64 Technology, Intel AES New Instructions
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s) M.2 Card
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics 620
Audio Output
7.1 channel surround
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
11.5 cm x 11.1 cm x 5.1 cm
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Storage Controller (2nd)
- M.2 Card
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Audio Output
Sound Output Mode
High Definition Audio
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 1 (free) x internal 2.5" , 1 (total) / 1 (free) x internal M.2 2242/2280
Slots
2 (total) / 2 (free) x SO-DIMM 260-pin
4 x USB 3.0 - Type A (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort/USB-C 3.1 Gen 2 , 2 x SATA-600 (2 internal)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Plug and Play, ICES-003, EN55024, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, KN24, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301 489-1, EN 300 893, CISPR32/EN55032, KN32, AS/NZS 2772.2, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
Power adapter
Power Provided
65 Watt
11.5 cm
11.1 cm
5.1 cm
Intel NUC Baby Canyon Core i3-7100U DDR4 M.2 PCIe USB3.1 Barebone Bundle deal on Intel NUC Baby Canyon Core i3-7100U DDR4 M.2 PCIe USB3.1 Barebone
£397.26
saving £8.33
£313.27
Brand: Intel
Price Range Ex VAT: 150 - 300
