Intel GIGABIT CT DESKTOP RJ45 PCIE B
Quicklinx: 79DLWS00 Mfr#: EXPI9301CTBLK
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC, Unix
Type: Network adapter
£25.88 ex VAT
£31.05 inc VAT
For PCs with PCI Express (PCIe) slots, the Intel Gigabit CT Desktop Adapter offers the newest technology for maximizing system performance and increasing end-user productivity. Specifically, the Intel Gigabit CT Desktop Adapter uses auto- negotiation to ensure the adapter runs at the highest available network speed (10, 100, or 1000 Mbps), and maintains full bandwidth capacity with the dedicated bandwidth of a PCIe input/output (I/O) bus to provide connectivity you can count on. Based on the low-power Intel 82574L Gigabit Ethernet Controller, this desktop adapter offers optimal performance in a low-cost, low-power, compact profile. Teaming support and an array of other advanced features enable customers to use this adapter as an entry-level server adapter as well.
Intel Ethernet - It Just Works!
Intel Gigabit CT Desktop Adapter - network adapter
Network adapter
Packaged Quantity
20 (specifications are for single item)
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.1
Ports
Gigabit Ethernet
11.9 cm x 5.5 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
1 x 82574L - Intel
IEEE 802.3z, IEEE 802.1p, WfM 2.0
Microsoft DOS, Microsoft Windows 2000, Microsoft Windows Server 2003, Novell NetWare 6.5, Microsoft Windows XP SP2, SCO OpenServer 6, FreeBSD 7.0, VMware ESX Server 3.x, FreeBSD 5.x or later, UnixWare 7.1.x, Microsoft Windows Server 2008, SuSE Linux Enterprise Server 10 SP1, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
Microsoft Certification
Compatible with Windows 7
Packaged Quantity
Network adapter
PCI Express x1
PCIe 1.1
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
TCP/IP, UDP/IP
Remote Management Protocol
SNMP, DMI 2.0
Status Indicators
Port transmission speed, link/activity
Full duplex capability, ACPI support, auto-negotiation, load balancing, wake on LAN (WOL), TCP/IP offloading, Jumbo Frames support
Processor / Memory
1 x 82574L - Intel
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x1 - low-profile
Low-profile bracket
FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC, RoHS
Package Type
Bulk
Software Included
Intel PROSet
Additional Requirements
PCIe slot
11.9 cm
5.5 cm
Limited warranty - lifetime
55 °C
0 - 90% (non-condensing)
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Compatibility: Unix
Brand: Intel
Price Range Ex VAT: 0 - 50
