For PCs with PCI Express (PCIe) slots, the Intel Gigabit CT Desktop Adapter offers the newest technology for maximizing system performance and increasing end-user productivity. Specifically, the Intel Gigabit CT Desktop Adapter uses auto- negotiation to ensure the adapter runs at the highest available network speed (10, 100, or 1000 Mbps), and maintains full bandwidth capacity with the dedicated bandwidth of a PCIe input/output (I/O) bus to provide connectivity you can count on. Based on the low-power Intel 82574L Gigabit Ethernet Controller, this desktop adapter offers optimal performance in a low-cost, low-power, compact profile. Teaming support and an array of other advanced features enable customers to use this adapter as an entry-level server adapter as well.
Intel Ethernet - It Just Works!
- Intel Gigabit CT Desktop Adapter - network adapter - PCIe
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.1
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1000 Mbps
- Processor
- 1 x Intel 82574L
- Microsoft Certification
- Compatible with Windows 7
- Network adapter
- Form Factor
- PCI Express x1
- PCIe 1.1
- Connectivity Technology
- Wired
- Cabling Type
- 1000 Mbps
- Intel I/O Acceleration Technology (I/OAT), Virtual Machine Device Queues (VMDq)
Processor / Memory
- Processor
- 1 x Intel 82574L
- 1 x network - RJ-45
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket, full-height bracket
- RoHS
- Software Included
- Intel PROSet
- Additional Requirements
- PCIe slot
