The XDACBL1M is a 1 meter (3.3 ft) SFP+ 10 GbE Direct Attach passive copper cable. The XDACBL1M SFP+ Direct Attach cables offer a highly cost-effective way to connect within racks and across adjacent racks and are fully compatible with the Intel Ethernet Converged Network Adapter X520 Family (X520 product codes: E10G42BTDA, E10G41BFSR, E10G42BFSR, E10G41BFLR). The Intel Ethernet SFP+ Twinaxial Cables are compliant to the latest SFP+ MSA (Multi-source Agreement) with a reduced power budget and lower port cost compared to optical solutions. Intel Ethernet - It Just Works!
- Intel Ethernet SFP+ Twinaxial Cable XDACBL1M - direct attach cable - 1 m
- Direct attach cable
- Technology
- Twinaxial
- Length
- 1 m
- Connector
- SFP+ - male
- Connector (Second End)
- SFP+ - male
- Designed For
- Ethernet Converged Network Adapter X520-DA2, X520-SR1, X520-SR2; Ethernet Server Adapter X520-SR2
- Network Cable Type
- Technology
- Twinaxial
- Length
- 1 m
- Connector
- SFP+ - male
- SFP+ - male
- Designed For
- Intel Ethernet Converged Network Adapter X520-DA2, X520-SR1, X520-SR2 , Intel Ethernet Server Adapter X520-SR2
