Intel Core i7-8700K 8th Gen S1151 3.70GHz 12MB Cache Coffee Lake
Quicklinx: D54GWS00 Mfr#: BX80684I78700K
Socket: LGA1151 Socket
Type: Core i7
Clock Speed: 3.7GHz
Cache Memory: 12MB
  • Core i7
£312.08 ex VAT
£374.49 inc VAT
8th Gen Intel® Core™ i7 Processors
Equipped with Intel® Turbo Boost Technology 2.0, your computer will have the power and responsiveness to help your productivity soar. Experience amazing gaming performance, seamlessly edit and share 360 video, and enjoy fantastic 4K Ultra HD entertainment– all with the lightning speed data transfers of Thunderbolt™ 3 technology.
  • Go to the next level of multi-core performance
    Intel Core i7 processors deliver an incredible breakthrough in quad-core performance and feature the latest innovations in processor technologies.
  • Intel smart cache
    It provides a higher-performance, more efficient cache subsystem. Optimized for industry leading multi-threaded games!
  • Intel QuickPath interconnect
    It is designed for increased bandwidth and low latency. It can achieve data transfer speeds as high as 25.6 GB/sec.
  • Integrated memory controller
    It enables three channels of DDR3 1066 MHz memory. This memory controller's lower latency and higher memory bandwidth delivers amazing performance for data-intensive applications.
  • Intel HD boost
    It significantly improves a broad range of multimedia and compute-intensive applications. The 128-bit SSE instructions are issued at a throughput rate of one per clock cycle, allowing a level of processing efficiency with SSE4 optimized applications.
Intel Core i7 8700K / 3.7 GHz processor
Processor Type
Intel Core i7 8700K (8th Gen)
Number of Cores
6-core / 12 threads
Cache
12 MB
Integrated Graphics
Intel UHD Graphics 630
Compatible Processor Socket
LGA1151 Socket
Processor Qty
1
Clock Speed
3.7 GHz
Max Turbo Speed
4.7 GHz
Manufacturing Process
14 nm
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, Intel Trusted Execution Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel Turbo Boost Technology 2.0, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Intel vPro Technology, Idle States, Intel VT-x with Extended Page Tables (EPT), Intel Identity Protection Technology, Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0), Intel OS Guard, Intel Software Guard Extensions (SGX), Intel Memory Protection Extensions (MPX), Intel Optane Memory Supported, Intel Boot Guard
3-year warranty
Type / Form Factor
Number of Cores
6-core
Number of Threads
12 threads
Cache
12 MB
Cache Memory Details
12 MB
Processor Qty
1
Clock Speed
3.7 GHz
Max Turbo Speed
4.7 GHz
LGA1151 Socket
14 nm
Thermal Design Power
95 W
PCI Express Revision
3.0
PCI Express Configurations
1x16, 2x8, 1x8+2x4
PCI Express Lanes Qty
16
Architecture Features
Integrated Graphics
Base Frequency
350 MHz
Max Dynamic Frequency
1.2 GHz
Max Supported Memory Size
64 GB
Max Supported Resolution
4096x2304@24Hz (HDMI), 4096x2304@60Hz (eDP), 4096x2304@60Hz (DP)
Intel Clear Video Technology, Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Triple Display Capable
Package Type
Intel Boxed
Limited warranty - replacement - 3 years
Type: Core i7
Clock Speed: 3.7GHz
Cache Memory: 12MB
Brand: Intel
Price Range Ex VAT: 300 - 500
