Intel Core i7-7820X 2.40GHz Skylake X S2066 11MB Cache Box
Quicklinx: CYPQWS00 Mfr#: BX80673I77820X
Socket: LGA2066 Socket
Type: Core i7
Clock Speed: 3.6GHz
  • Core i7
£484.24 ex VAT
£581.08 inc VAT
Intel® Core™ X-Series Processors
With up to 18 cores and 36 threads the Intel® Core™ X-series processor family is Intel's most powerful ever. Turn your PC into a studio: produce amazing 4K or 360-degree videos, stunning photos, or amazing music. This is the ultimate tool for gaming and virtual reality experience the power to do it all.
Intel® Core™ i7-7820X Processor
8-cores, 16-threads with HyperThreading
3.6GHz clock speed
4.3GHz Turbo speed
11MB Cache
Quad-channel DDR4
28 PCI-E lanes
Maximize Performance
Whether you are working on your latest feature film or the next episode of a YouTube* series, the unlocked Intel® Core™ X-series processors are designed to scale to your performance needs by using the two fastest cores at higher frequencies and up to 18 cores when extreme mega tasking is required. Experience extreme performance, immersive 4K visuals, high speed storage and memory, and the latest technological advancements – all designed to get you from planning to final product faster than ever.
Power Your Creativity
Spend more time creating and less time waiting. The Intel® Core X-series processor can handle your most demanding workload. Upload and edit your 360° videos quickly and experience VR videos–all in stunning 4K. There are no limits to what you can create on your new computer.
Mega-Task to the Extreme
When creating your best work, you need the most responsive technology to handle multiple, CPU-intensive tasks at once. With an Intel® Core X-series processor, you can edit your video, render 3D effects, and compose the soundtrack simultaneously without compromising your computer’s performance.
Overclock with Confidence
The Intel® Core™ X-series processor family is unlocked to provide additional headroom. New features include the ability to overclock each core individually, AVX ratio controls for more stability, and VccU voltage control for extreme scenarios. Combined with tools like Intel's Extreme Tuning Utility (Intel® XTU) and Extreme Memory Profile (Intel® XMP), you have a powerful kit for maximizing performance.
Intel® Smart Cache
Improve efficiency with Intel® Smart Cache technology. All cores now have access to the entire last-level cache, pre-fetching data before requests are made. Intel® Smart Cache also features a new power-saving feature that dynamically flushes memory based on demand or during periods of inactivity, ensuring your applications keep up with your demands.
Intel® Turbo Boost Max Technology 3.0
Increase your computer’s processing power. Available on Intel® Core X-series processors, Intel® Turbo Boost Max Technology 3.0 identifies your processor's two fastest cores and directs your most critical workloads there2. With improved single-threaded performance, you to get the best performance possible out of your computer.
Intel® X299 Chipset and Intel® Core™ X-Series Processors for the Ultimate Platform
The Intel® X299 chipset paired with the Intel® Core™ X-series processors provide a world class platform for gaming, content creation and over-clocking. Whether it is responsiveness, expandability or performance you crave, this platform has you covered. Integrated USB 3.0 makes moving files to your tablet and smartphone blazing fast. The platform also provides RAID support on PCI Express* and Serial ATA storage devices, fast data transfers with support for PCIe 3.0 storage devices and finally, Intel® Optane™ memory support. Want to push the envelope with overclocking? The Intel® X299 chipset and Intel® Core™ X-series processor family bring new unlocked base clock capabilities. Unlock your individual cores and memory frequencies to amazing levels while having the flexibility to keep other areas within specification. With support for Intel® Extreme Memory Profile (Intel® XMP), Intel® Extreme Tuning Utility (Intel® XTU), and the Intel® Performance Tuning Protection Package Plan the capabilities of the Intel® X299 chipset and new Intel® Core™ X-series processors are a threat to every overclocking world record.
Identifies the two fastest cores on the processor die to provide improved single threaded performance on X-series processors. The driver provided along with the feature allows end users to direct workloads to the fastest core by setting priority to preferred applications.
Intel® Turbo Boost Technology 2.0
Dynamically increases the processor’s frequency, as needed, by taking advantage of thermal and power headroom when operating below specified limits.
Intel® Hyper-Threading Technology Delivers two processing threads per physical core. Highly threaded applications can get more work done in parallel, completing tasks sooner.
Integrated Memory Controller
Supports up to 4 channels of DDR4-2666 memory with 1 DIMM per channel. Support for the Intel® Extreme Memory Profile (Intel® XMP) specification, revision 2.0 for DDR4.
Provides performance improvements as well as fast app response times for system acceleration and responsiveness.
Intel® Smart Cache
Massive amounts of shared cached allows faster access to your data by enabling dynamic and efficient allocation of the cache to match the needs of each core significantly reducing latency to frequently used data and improving performance.
Overclocking Enabled
Fully unlocked core multipliers, power, base clock and DDR4 memory ratios for amazing flexibility with overclocking.
Chipset/Motherboard Compatibility
Supported by the Intel® X299 chipset.
Intel® Advanced Encryption Standard
A fast, secure AES engine for a variety of encryption apps, including whole disk encryption, file storage encryption, conditional access of HD content, internet security, and VOIP. Consumers benefit from protected internet and email content, plus fast, responsive disk encryption.
Intel® Virtualization Technology
Allows one hardware platform to function as multiple "virtual" platforms. Offers improved manageability by limiting downtime and maintaining productivity by isolating computing activities into separate partitions.
PCI Express 3.0 Interface
Offers up to 8GT/S for fast access to peripheral devices and networking up to 40 lanes.
Green Technology
Manufactured with lead-free and halogen-free10 component packages.
  • Go to the next level of multi-core performance
    Intel Core i7 processors deliver an incredible breakthrough in quad-core performance and feature the latest innovations in processor technologies.
  • Intel smart cache
    It provides a higher-performance, more efficient cache subsystem. Optimized for industry leading multi-threaded games!
  • Intel QuickPath interconnect
    It is designed for increased bandwidth and low latency. It can achieve data transfer speeds as high as 25.6 GB/sec.
  • Integrated memory controller
    It enables three channels of DDR3 1066 MHz memory. This memory controller's lower latency and higher memory bandwidth delivers amazing performance for data-intensive applications.
  • Intel HD boost
    It significantly improves a broad range of multimedia and compute-intensive applications. The 128-bit SSE instructions are issued at a throughput rate of one per clock cycle, allowing a level of processing efficiency with SSE4 optimized applications.
Intel Core i7 7820X X-series / 3.6 GHz processor
Processor Type
Intel Core i7 7820X X-series (7th Gen)
Number of Cores
8-core / 16 threads
Cache
11 MB
Compatible Processor Socket
LGA2066 Socket
Processor Qty
1
Clock Speed
3.6 GHz
Max Turbo Speed
4.3 GHz
Manufacturing Process
14 nm
Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel Turbo Boost Technology 2.0, Intel AES New Instructions (AES-NI), Intel Virtualization Technology for Directed I/O (VT-d), Intel Advanced Vector Extensions 2 (AVX2.0), Intel Turbo Boost Max Technology 3.0, Intel Optane Memory Supported, Intel Advanced Vector Extensions 512 (AVX-512)
3-year warranty
Type / Form Factor
Number of Cores
8-core
Number of Threads
16 threads
Cache
11 MB
Cache Memory Details
L3 - 11 MB
Processor Qty
1
Clock Speed
3.6 GHz
Max Turbo Speed
4.3 GHz
LGA2066 Socket
14 nm
Thermal Design Power
140 W
PCI Express Revision
3.0
PCI Express Lanes Qty
28
Architecture Features
Package Type
Intel Boxed
Limited warranty - 3 years
Type: Core i7
Clock Speed: 3.6GHz
Brand: Intel
Price Range Ex VAT: 300 - 500
