Intel Core i7-7700 3.60GHz S1151 8MB Cache Kaby Lake CPU
Quicklinx: CGWJWS00 Mfr#: BX80677I77700
Socket: LGA1151 Socket
Type: Core i7
Clock Speed: 3.6GHz
Cache Memory: 8MB
  • Core i7
Hurry, only 1 left in stock!
£243.28 ex VAT
£291.93 inc VAT
Express delivery Order within the next 13 hours for delivery tomorrow
New 7th Gen Intel® Core™ i7 processors deliver everything you need for a revolutionary gaming experience. Whether you want to boost performance, experience the latest in overclocking, or upgrade with room to add on later, you won’t be disappointed.
POWERFUL
Built for those who want to experience gaming, VR and 4K content as intended, Intel® Core™ i7 processors offer the latest technologies to deliver your next gamer-grade upgrade.
CUSTOMIZABLE
Move to a more customizable setup with unlocked Intel® Core™ i7 processors and gain up to 28% better performance versus a 3-year-old desktop PC as a result. Thanks to new expanded overclocking modifiers, you can dial up your clock speed with unprecedented precision and control.
Processor Number - i7-7700
No. of Cores - 4
No. of Threads - 8
Processor Base Frequency - 3.60 GHz
Cache - 8 MB
Bus Speed - 100 MHz DMI
TDP - 65 W
Sockets Supported - LGA1151
Intel® Hyper-Threading Technology - Yes
Intel® Virtualization Technology (VT-x) - Yes
Trusted Execution Technology - Yes
  • Go to the next level of multi-core performance
    Intel Core i7 processors deliver an incredible breakthrough in quad-core performance and feature the latest innovations in processor technologies.
  • Intel smart cache
    It provides a higher-performance, more efficient cache subsystem. Optimized for industry leading multi-threaded games!
  • Intel QuickPath interconnect
    It is designed for increased bandwidth and low latency. It can achieve data transfer speeds as high as 25.6 GB/sec.
  • Integrated memory controller
    It enables three channels of DDR3 1066 MHz memory. This memory controller's lower latency and higher memory bandwidth delivers amazing performance for data-intensive applications.
  • Intel HD boost
    It significantly improves a broad range of multimedia and compute-intensive applications. The 128-bit SSE instructions are issued at a throughput rate of one per clock cycle, allowing a level of processing efficiency with SSE4 optimized applications.
Intel Core i7 7700 / 3.6 GHz processor
Processor Type
Intel Core i7 7700 (7th Gen)
Number of Cores
Quad-Core / 8 threads
Cache
8 MB
Integrated Graphics
Intel HD Graphics 630
Compatible Processor Socket
LGA1151 Socket
Processor Qty
1
Clock Speed
3.6 GHz
Max Turbo Speed
4.2 GHz
Manufacturing Process
14 nm
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, Intel Trusted Execution Technology, Intel Turbo Boost Technology 2.0, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Intel Virtualization Technology for Directed I/O (VT-d), Intel vPro Technology, Idle States, Intel Identity Protection Technology, Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0), Intel TSX-NI, Intel Stable Image Platform Program (SIPP), Intel Software Guard Extensions (SGX), Intel Memory Protection Extensions (MPX), Intel Device Protection Technology with Boot Guard
3-year warranty
Type / Form Factor
Number of Cores
Quad-Core
Number of Threads
8 threads
Cache
8 MB
Cache Memory Details
Smart Cache - 8 MB
Processor Qty
1
Clock Speed
3.6 GHz
Max Turbo Speed
4.2 GHz
LGA1151 Socket
14 nm
Thermal Design Power
65 W
Thermal Specification
100 °C
PCI Express Revision
3.0
PCI Express Configurations
1x16, 2x8, 1x8+2x4
PCI Express Lanes Qty
16
Architecture Features
Integrated Graphics
Base Frequency
350 MHz
Max Dynamic Frequency
1.15 GHz
Max Supported Memory Size
64 GB
Max Supported Resolution
4096x2304@24Hz (HDMI), 4096x2304@60Hz (eDP), 4096x2304@60Hz (DP)
Intel Clear Video Technology, Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Triple Display Capable
Package Type
Intel Boxed
Limited warranty - replacement - 3 years
Type: Core i7
Clock Speed: 3.6GHz
Cache Memory: 8MB
Brand: Intel
Price Range Ex VAT: 150 - 300
