Intel Core i7-6700 3.40GHz 6th Gen Skylake CPU S1151 8MB Processor
Quicklinx: BH1WWS00 Mfr#: BX80662I76700
Socket: LGA1151 Socket
Type: Core i7
Clock Speed: 3.4GHz
  • Core i7
13 in stock
£245.97 ex VAT
£295.16 inc VAT
Looking for an Amazing Processor for your next desktop PC? Look no further than 6th Gen Intel Core processors. With amazing performance and stunning visuals, PCs powered by 6th Gen Intel Core processors will help take things to the next level and transform how you use a PC. The performance of 6th Gen Intel Core processors enable great user experiences today and in the future, including no passwords and more natural user interfaces. When paired with Intel RealSense technology and Windows 10, 6th Gen Intel Core processors can help remove the hassle of remembering and typing in passwords.
The 6th generation Intel® Core™ i7 processors deliver a new class of computing with a host of new features to power the next generation of laptops and 2 in 1 PCs. Expect lighting fast speeds and peak performance through even the toughest of tasks and games. The built-in revolutionary Intel® Hyper-Threading Technology allows each processor core to work on two tasks at the same time for smoother multitasking while Intel® Iris™ graphics delivers stunning 3D visuals and faster, more advanced video and photo editing. Game the way you want and push the boundaries with overclocking for your most demanding gaming needs. The ultimate in peak performance.
  • Go to the next level of multi-core performance
    Intel Core i7 processors deliver an incredible breakthrough in quad-core performance and feature the latest innovations in processor technologies.
  • Intel smart cache
    It provides a higher-performance, more efficient cache subsystem. Optimized for industry leading multi-threaded games!
  • Intel QuickPath interconnect
    It is designed for increased bandwidth and low latency. It can achieve data transfer speeds as high as 25.6 GB/sec.
  • Integrated memory controller
    It enables three channels of DDR3 1066 MHz memory. This memory controller's lower latency and higher memory bandwidth delivers amazing performance for data-intensive applications.
  • Intel HD boost
    It significantly improves a broad range of multimedia and compute-intensive applications. The 128-bit SSE instructions are issued at a throughput rate of one per clock cycle, allowing a level of processing efficiency with SSE4 optimized applications.
Intel Core i7 6700 / 3.4 GHz processor
Processor Type
Intel Core i7 6700 (6th Gen)
Number of Cores
Quad-Core / 8 threads
Cache
8 MB
Integrated Graphics
Intel HD Graphics 530
Compatible Processor Socket
LGA1151 Socket
Processor Qty
1
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
Manufacturing Process
14 nm
Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, Intel Trusted Execution Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel Turbo Boost Technology 2.0, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Intel Virtualization Technology for Directed I/O (VT-d), Intel vPro Technology, Idle States, Intel VT-x with Extended Page Tables (EPT), Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0), Intel TSX-NI, Intel Stable Image Platform Program (SIPP), Intel OS Guard, Intel Small Business Advantage
Type / Form Factor
Number of Cores
Quad-Core
Number of Threads
8 threads
Cache
8 MB
Cache Memory Details
Smart Cache - 8 MB
Processor Qty
1
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
LGA1151 Socket
14 nm
Thermal Design Power
65 W
PCI Express Revision
3.0
PCI Express Configurations
1x16, 2x8, 1x8+2x4
PCI Express Lanes Qty
16
Architecture Features
Integrated Graphics
Base Frequency
350 MHz
Max Dynamic Frequency
1.15 GHz
Max Supported Memory Size
64 GB
Max Supported Resolution
4096x2304@24Hz (HDMI), 4096x2304@60Hz (eDP), 4096x2304@60Hz (DP)
Intel Clear Video Technology, Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Intel Wireless Display (WiDi), Intel Insider, Triple Display Capable
Package Type
Intel Boxed
Type: Core i7
Clock Speed: 3.4GHz
Brand: Intel
Price Range Ex VAT: 150 - 300
