This Processor requires an X99 Motherboard & DDR4 Memory.
8 - The new power number. It looks like an infinite loop, which is appropriate as that is the power you possess with the new Intel® Core™ i7-5960X processor.
8 independent cores of unbelievable power that encourage you to become the digital content creator or gamer you always wanted to be. Need cores to render? Check. Need cores to compile? Check. Need core to seek and destroy in the latest game? Check. It seems almost unfair to add Intel® Hyper Threading Technology for a total of 16 threads at your disposal. You want burst speed performance for those jobs that require a bit more frequency? Intel® Turbo Boost Technology has that covered. But that little voice inside of you is saying you want even more? Let that voice know that the processor is unlocked and is ready for you to tune it to fit your demanding needs. Tune cores, power, memory, or whatever else you need to tune to make your system fit your needs.
- Fully Unlocked Processor - 8 Core
- Massive Multi-Thread Performance
- Halo Platform for Gaming, Overclocking and Content Creation
- 1st Intel Desktop CPU with DDR4 Support
- 22nm Haswell Microarchitecture
- Intel® Turbo Boost Technology 2.0
- Intel ® Hyper-Threading Technology
- 1st 8 core Desktop Processor
Go to the next level of multi-core performance
Intel Core i7 processors deliver an incredible breakthrough in quad-core performance and feature the latest innovations in processor technologies. -
Intel smart cache
It provides a higher-performance, more efficient cache subsystem. Optimized for industry leading multi-threaded games! -
Intel QuickPath interconnect
It is designed for increased bandwidth and low latency. It can achieve data transfer speeds as high as 25.6 GB/sec. -
Integrated memory controller
It enables three channels of DDR3 1066 MHz memory. This memory controller's lower latency and higher memory bandwidth delivers amazing performance for data-intensive applications. -
Intel HD boost
It significantly improves a broad range of multimedia and compute-intensive applications. The 128-bit SSE instructions are issued at a throughput rate of one per clock cycle, allowing a level of processing efficiency with SSE4 optimized applications.
- Intel Core i7 Extreme Edition 5960X / 3 GHz processor - Box
- Product Type
- Processor
- Processor Type
- Intel Core i7 Extreme Edition 5960X (5th Gen)
- Number of Cores
- 8-core / 16 threads
- Cache
- 20 MB
- Compatible Processor Socket
- LGA2011-v3 Socket
- Processor Qty
- 1
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Manufacturing Process
- 22 nm
- Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, streaming SIMD extensions 4.2, Intel Turbo Boost Technology 2.0, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Intel Virtualization Technology for Directed I/O (VT-d), Intel Smart Cache, Idle States, Intel VT-x with Extended Page Tables (EPT), Intel Identity Protection Technology, Intel Advanced Vector Extensions 2 (AVX2.0), Intel Smart Response Technology
- 3-year warranty
- Product Type
- Processor
- Type / Form Factor
- Number of Cores
- 8-core
- Number of Threads
- 16 threads
- Cache
- 20 MB
- Cache Memory Details
- Smart Cache - 20 MB
- Processor Qty
- 1
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- LGA2011-v3 Socket
- 22 nm
- Thermal Design Power
- 140 W
- Architecture Features
Cache Memory
- Installed Size
- 20 MB
- Package Type
- Intel Boxed
- Limited warranty - 3 years
