Intel Core i3-6300 3.80GHz S1151 4MB Cache Retail CPU Processor
Quicklinx: BLRSWS00 Mfr#: BX80662I36300
Socket: LGA1151 Socket
Type: Core i3
Clock Speed: 3.8GHz
  • Core i3
£122.18 ex VAT
£146.61 inc VAT
The Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. This processor comes equipped with Intel HD graphics, an advanced video engine that delivers smooth, high-quality HD video playback, and advanced 3D capabilities, providing an ideal graphics solution for everyday computing.
A smart choice for home and office, the Intel Core i3 processor also features Intel Hyper-Threading technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Do not let too many open applications slow you and your PC down. Get smart performance now.
  • Intel smart cache
    Intel smart cache is shared cache dynamically allocated to each processor core, based on workload. This efficient, dual-core-optimized implementation increases the probability that each core can access data from the fast cache, significantly reducing latency to frequently used data and improving performance.
  • Intel HD graphics
    Provide superb visual performance for sharper images, richer color, and life-like video and audio.
Intel Core i3 6300 / 3.8 GHz processor
Processor Type
Intel Core i3 6300 (6th Gen)
Number of Cores
Dual-Core / 4 threads
Cache
4 MB
Integrated Graphics
Intel HD Graphics 530
Compatible Processor Socket
LGA1151 Socket
Processor Qty
1
Clock Speed
3.8 GHz
Manufacturing Process
14 nm
Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Intel Virtualization Technology for Directed I/O (VT-d), Idle States, Intel VT-x with Extended Page Tables (EPT), Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0), Intel OS Guard, Intel Small Business Advantage
Type / Form Factor
Number of Cores
Dual-Core
Number of Threads
4 threads
Cache
4 MB
Cache Memory Details
Smart Cache - 4 MB
Processor Qty
1
Clock Speed
3.8 GHz
LGA1151 Socket
14 nm
Thermal Design Power
47 W
PCI Express Revision
3.0
PCI Express Configurations
1x16, 2x8, 1x8+2x4
PCI Express Lanes Qty
16
Architecture Features
Integrated Graphics
Base Frequency
350 MHz
Max Dynamic Frequency
1.15 GHz
Max Supported Memory Size
64 GB
Max Supported Resolution
4096x2304@24Hz (HDMI), 4096x2304@60Hz (eDP), 4096x2304@60Hz (DP)
Intel Clear Video Technology, Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Intel Wireless Display (WiDi), Intel Insider, Triple Display Capable
Package Type
Intel Boxed
Type: Core i3
Clock Speed: 3.8GHz
Brand: Intel
Price Range Ex VAT: 100 - 150
