The Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. This processor comes equipped with Intel HD graphics, an advanced video engine that delivers smooth, high-quality HD video playback, and advanced 3D capabilities, providing an ideal graphics solution for everyday computing.
A smart choice for home and office, the Intel Core i3 processor also features Intel Hyper-Threading technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Do not let too many open applications slow you and your PC down. Get smart performance now.
Intel smart cache
Intel smart cache is shared cache dynamically allocated to each processor core, based on workload. This efficient, dual-core-optimized implementation increases the probability that each core can access data from the fast cache, significantly reducing latency to frequently used data and improving performance.
- Intel Core i3 4170 / 3.7 GHz processor - Box
- Product Type
- Processor
- Processor Type
- Intel Core i3 4170 (4th Gen)
- Number of Cores
- Dual-Core / 4 threads
- Cache
- 3 MB
- Integrated Graphics
- Intel HD Graphics 4400
- Compatible Processor Socket
- LGA1150 Socket
- Processor Qty
- 1
- Clock Speed
- 3.7 GHz
- Manufacturing Process
- 22 nm
- Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Idle States, Intel VT-x with Extended Page Tables (EPT), Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0)
- 3-year warranty
- Product Type
- Processor
- Type / Form Factor
- Number of Cores
- Dual-Core
- Number of Threads
- 4 threads
- Cache
- 3 MB
- Cache Memory Details
- 3 MB
- Processor Qty
- 1
- Clock Speed
- 3.7 GHz
- LGA1150 Socket
- 22 nm
- Thermal Design Power
- 54 W
- Thermal Specification
- 72 °C
- PCI Express Revision
- 3.0
- PCI Express Configurations
- 1x16, 2x8, 1x8+2x4
- PCI Express Lanes Qty
- 16
- Architecture Features
Integrated Graphics
- Base Frequency
- 350 MHz
- Max Dynamic Frequency
- 1.15 GHz
- Max Supported Memory Size
- 2 GB
- Max Supported Resolution
- 4096x2304@24Hz (HDMI), 3840x2160@60Hz (DP), 3840x2160@60Hz (eDP), 1920x1200@60Hz (VGA)
- Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Intel Wireless Display (WiDi), Triple Display Capable
- Package Type
- Intel Boxed
- Limited warranty - 3 years
