Intel Core i3-4170 3.70GHz SKT1150 3MB Processor
Quicklinx: B75YWS00 Mfr#: BX80646I34170
  • Core i3
The Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. This processor comes equipped with Intel HD graphics, an advanced video engine that delivers smooth, high-quality HD video playback, and advanced 3D capabilities, providing an ideal graphics solution for everyday computing.
A smart choice for home and office, the Intel Core i3 processor also features Intel Hyper-Threading technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Do not let too many open applications slow you and your PC down. Get smart performance now.
  • Intel smart cache
    Intel smart cache is shared cache dynamically allocated to each processor core, based on workload. This efficient, dual-core-optimized implementation increases the probability that each core can access data from the fast cache, significantly reducing latency to frequently used data and improving performance.
Intel Core i3 4170 / 3.7 GHz processor - Box
Processor Type
Intel Core i3 4170 (4th Gen)
Number of Cores
Dual-Core / 4 threads
Cache
3 MB
Integrated Graphics
Intel HD Graphics 4400
Compatible Processor Socket
LGA1150 Socket
Processor Qty
1
Clock Speed
3.7 GHz
Manufacturing Process
22 nm
Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Idle States, Intel VT-x with Extended Page Tables (EPT), Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0)
3-year warranty
Type / Form Factor
Number of Cores
Dual-Core
Number of Threads
4 threads
Cache
3 MB
Cache Memory Details
3 MB
Processor Qty
1
Clock Speed
3.7 GHz
LGA1150 Socket
22 nm
Thermal Design Power
54 W
Thermal Specification
72 °C
PCI Express Revision
3.0
PCI Express Configurations
1x16, 2x8, 1x8+2x4
PCI Express Lanes Qty
16
Architecture Features
Integrated Graphics
Base Frequency
350 MHz
Max Dynamic Frequency
1.15 GHz
Max Supported Memory Size
2 GB
Max Supported Resolution
4096x2304@24Hz (HDMI), 3840x2160@60Hz (DP), 3840x2160@60Hz (eDP), 1920x1200@60Hz (VGA)
Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Intel Wireless Display (WiDi), Triple Display Capable
Package Type
Intel Boxed
Limited warranty - 3 years
