PC Performance, Mobile Flexibility
Get ready for amazing. The Intel® Compute Stick is a tiny device the size of a pack of gum that can transform any HDMI TV or monitor into a complete computer. But it's what's inside that's really incredible: an Intel® Atom Quad Core processor - with blazing fast speed that gives you performance for work, play, or both -- and lets you upgrade to a world of new experience. The Intel® Compute Stick delivers everything you love about a desktop computer in a device that fits in the palm of your hand.
Key Features
- Intel Atom Quad-Core Processor
- 2GB of built-in Memory
- Intel HD Graphics
- 32GB eMMC built-in Storage
- Windows 10 Home
- McAfee AntiVirus Plus
- 2 year Warranty
Connect. Compute. It's That Simple.
Transform your display into a fully functional computer with the Compute Stick from Intel. This over-sized thumb drive PC offers the performance similar to your other computer and allows you to stream online videos, play games, work on projects, and more. On the inside, it sports a quad-core Intel Atom processor along with 2GB of RAM so you can simultaneously run multiple software programs. It connects to any HDMI-equipped monitor or TV and delivers high-resolution images utilizing integrated Intel HD Graphics. Additionally, it supports multi-channel audio through the same HDMI connection. For long-term storage, it is outfitted with a 32GB flash storage drive that provides instant access to your programs and data. You can expand its storage capacity by inserting an optional micro-SD card into the memory card slot, which can accept a 128GB micro-SDXC card. Furthermore, it is pre-installed with the Windows 10 operating system with Bing to complete the ready-to-go out-of-the-box PC experience.
This Compute Stick PC delivers full plug-and-play connectivity by offering an integrated USB 2.0 port for connecting with a printer, storage drive, or other USB devices. With built-in 802.11b/g/n Wi-Fi, it lets you wirelessly access the Internet to check emails and browse websites as well as a network for sharing files and videos. Another included wireless feature is Bluetooth 4.0 that lets you control the Stick PC with your Bluetooth keyboard and mouse from the couch in a living room or on the other side of a conference room. Bundled along with the Intel Compute Stick to ensure you stay productive are an HDMI extender cable and a 5V, 2A micro USB adapter for providing it with power.
Use your television for more than TV
Looking to bring computing to new places? The Intel Compute Stick is exactly what you're looking for. It transforms any HDMI TV or monitor into a full computer, allowing you to search the web, share your vacation photos, keep up on your email or do any of the tasks that you do on your computer today. All you need is a wireless keyboard and mouse and you're set. -
Transform your monitors
Whether you need to develop some digital signage, add intelligence to a conference room projector or deploy a room full of thin clients, the Intel Compute Stick has the right blend of performance, cost, and size to do the job. -
Quality, performance, value
Take it out of the box. Plug it in to your television. You just turned your TV into a powerful computer with ample speed and storage. The Intel Compute Stick takes up so little space and costs so few dollars. -
Quad-core Intel Atom processor
This innovative processor delivers max performance but uses minimum power - making the Intel Compute Stick both space and energy efficient. -
Intel HD graphics
Exceptional clarity makes for an exceptional visual experience. The Intel Compute Stick delivers HD wow, whether you're viewing videos, games, or photos. -
Intel HD audio
Get a high quality, multichannel sound experience, without an audio card. It's truly an immersive media experience that will have your ears seeing stars.
- Intel Compute Stick STCK1A32WFC - Atom Z3735F 1.33 GHz - 2 GB - 32 GB
- Personal computer - stick
- Processor
- 1 x Intel Atom Z3735F / 1.33 GHz ( 1.83 GHz ) ( Quad-Core )
- Processor Main Features
- Intel Virtualization Technology
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 2 GB DDR3L SDRAM - 1333 MHz
- Hard Drive
- 1 x flash 32 GB - eMMC
- Card Reader
- Graphics Controller
- Intel HD Graphics
- Networking
- 802.11b, 802.11g, 802.11n, Bluetooth 4.0
- OS Provided
- Windows 10 Home 32-bit Edition
- 3.76 cm x 10.34 cm x 1.25 cm
- 54 g
- Environmental Standards
- ENERGY STAR Qualified
- 2 year warranty Europe, Middle East, Turkey, Africa, Russia/CIS
- Personal computer
- Product Form Factor
- Stick
- Black
Processor / Chipset
- CPU
- Intel Atom Z3735F / 1.33 GHz
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 2 GB
- Technology
- DDR3L SDRAM
- Memory Speed
- 1333 MHz
- Configuration Features
- Provided memory is soldered
Hard Drive
- Flash
- Capacity
- 1 x 32 GB
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD, microSDXC UHS-I Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI
Audio Output
- High Definition Audio
- Wireless LAN Supported
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- 1 x USB 2.0 , 1 x HDMI
- Quantity of Items per Pack
- 10
- Cables Included
- HDMI extension cable
- ACPI
- Power adapter
Operating System / Software
- OS Provided
- Software
- ENERGY STAR Version
- 6.0
- Service & Support Details
- Limited warranty - 1 year
- 3.76 cm
- 10.34 cm
- 1.25 cm
- 54 g
- 0 °C
- 35 °C
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
