Intel Compute Card BLKCD1C64GK Intel Celeron N3450 4GB 64GB
Quicklinx: D8ZMWS00 Mfr#: BLKCD1C64GK
Processor Type: Celeron
Installed Memory: 4GB
Hard Drive Capacity: 64GB
Storage Type: Flash
Processor Model: N3450
  • Celeron
  • IEEE 802.11n
Hurry, only 3 left in stock!
£106.29 ex VAT
£127.54 inc VAT
This tiny computer has a universal interface which allows it to be plugged into any host device with an Intel Compute Card slot, including an Intel-designed dock. The modular nature of the Compute Card means that computing power can be found in unexpected places. Suddenly it is easy to integrate compute and connectivity into everything.
  • Simplified design
    Imagine if your customers could simply insert an Intel Compute Card and create smart devices. With the Compute Card's standard interface, designers and manufacturers are free to do what they do best - create amazing products - rather than learning how to integrate compute capabilities. The Compute Card along with Intel design guides and reference designs make it easy to create great products with compute power.
  • Refresh or upgrade
    The ability to swap out a card for upgrade makes the Intel Compute Card a natural choice for your commercial and consumer customers because it allows for refresh of the compute separate from the device. It also makes upselling easier because you can simply drop in a Compute Card with a more powerful processor.
  • Delayed integration
    The Intel Compute Card can enable advanced business models as well as mitigate risk and expense because OEMs, ODMs, and channel partners can add compute resources later in the manufacturing cycle. Equally important, retailers and channel members can now carry less inventory and manage their compute inventory loads closely.
Intel Compute Card CD1C64GK - card - Celeron N3450 1.1 GHz - 4 GB - 64 GB
Personal computer - card
Intel Celeron N3450 / 1.1 GHz (2.2 GHz) (Quad-Core)
Processor Main Features
Intel Virtualization Technology, Intel 64 Technology, Intel AES New Instructions
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 4 GB (max) - LPDDR3 SDRAM
Hard Drive
1 x flash 64 GB - eMMC
Graphics Controller
Intel HD Graphics 500
802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
5.5 cm x 9.45 cm x 5 mm
Limited warranty - 3 years
Personal computer
Product Form Factor
Card
Processor / Chipset
CPU
Max Turbo Speed
2.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 4 GB (max)
LPDDR3 SDRAM
Effective Memory Speed
1866 MHz
Dual channel memory architecture
Configuration Features
Provided memory is soldered
Hard Drive
Flash - eMMC
1 x 64 GB
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Audio Output
High Definition Audio
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
No power supply
5.5 cm
9.45 cm
5 mm
Intel Compute Card BLKCD1C64GK Intel Celeron N3450 4GB 64GB Bundle deal on Intel Compute Card BLKCD1C64GK Intel Celeron N3450 4GB 64GB
£205.46
Storage Type: Flash
Type: Personal computer
Case Style: Card
Brand: Intel
Price Range Ex VAT: 100 - 150
