Intel Cedar City Compute Stick M3-6Y30 4GB 64GB eMMC Windows 10
Quicklinx: BYQWWS00 Mfr#: BOXSTK2M3W64CC
Processor Type: Core m3
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 64GB
Storage Type: Flash
  • IEEE 802.11n
13 in stock
£289.24 ex VAT
£347.08 inc VAT
The Intel compute stick is a tiny device that can transform any HDMI TV or display into a complete computer. But what's inside is really incredible: an advanced processor for the performance you need to create brilliant presentations with graphics, create analytics models on a spreadsheet, or drive 4K digital signage. Just plug in the Intel compute stick into HDMI TV or monitor, connect your wireless keyboard and mouse and you're ready to go.
Intel® Core™ M Processor
Mobile computing without compromise
Thin, light, quiet and versatile. The new 6th generation Intel® Core™ processors built on 14 nm manufacturing process technology deliver great mobile performance, blazing-fast responsiveness and amazing battery life. This feature packed processor with built-in security is ready to take your productivity, creativity and entertainment to the next level. And, by enabling the exciting Windows® 10 features, 6th generation Intel® Core™ m3/m5/m7 processors empower you to unleash your imagination and explore the possibilities.1 2
By modernising your business with 6th generation Intel® Core™ M series vPro™ processor-based mobile devices, you can be confident they'll be ready for Windows® 10 when it's time to migrate. It's simply a better way to work.
Intel Compute Stick Productivity Usage Guide
By allowing you to transform any HDMI* display into a fully functional computer, the Intel® Compute Stick lets you stay productive anywhere you have an HDMI display. Ready to go out of the box, this new type of computing device has a quad-core Intel® Atom™ processor and offers the performance, quality, and value you expect from Intel. The system performs just like your other computers -- simply plug it into any HDMI monitor or TV, connect a wireless keyboard and mouse, and you can work when, where, and how you want. It's everything you love about your desktop computer in a device that fits in the palm of your hand.
Intel® Compute Stick Digital Signage Usage Guide
A new type of computing device, the Intel® Compute Stick enables you to transform a display into a fully functional digital signage solution via the display's HDMI* port. Ready to go out of the box, the Intel Compute Stick has a quad-core Intel® Atom™ processor and offers the performance, quality, and value you expect from Intel. The system performs just like your other computers. Simply plug it into any HDMI monitor, connect to the cloud for your data or access files locally, and you've got a simple digital sign or a point-of-sale (POS) display.
Intel® Compute Stick Thin Client Usage Guide
A new type of computing device that lets you compute in small spaces, the Intel® Compute Stick enables you to transform a display into a thin-client platform via an HDMI* port. Ready to go out of the box, the Intel Compute Stick has a quad-core Intel® Atom™ processor and offers the performance, quality, and value you expect from Intel. The system performs just like your other computers -- simply plug it into any HDMI display, connect your wireless keyboard and mouse, and you're ready to connect and collaborate in call centers, computer labs, or anywhere you're working.
Intel Compute Stick STK2m3W64CC - stick - Core m3 6Y30 1.6 GHz - 4 GB - 64 GB
Personal computer - stick
1 x Intel Core m3 (6th Gen) 6Y30 / 1.6 GHz (Dual-Core)
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
4 GB (installed) / 4 GB (max) - LPDDR3 SDRAM
Hard Drive
1 x flash 64 GB - eMMC
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics
802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.1
OS Provided
3.5 cm x 11.4 cm x 1.1 cm
Environmental Standards
TCO Certified
Limited warranty - 3 years
Personal computer
Product Form Factor
Stick
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 4 GB (max)
LPDDR3 SDRAM
Effective Memory Speed
1866 MHz
Dual channel memory architecture
Configuration Features
Provided memory is soldered
Hard Drive
Flash - eMMC
1 x 64 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI
Audio Output
High Definition Audio
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8260
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
1 x USB 3.0 , 1 x HDMI
Quantity of Items per Pack
5
SuperSpeed USB-C cable , HDMI extension cable
Theft/Intrusion Protection
Padlock loop
Power adapter
Operating System / Software
OS Provided
3.5 cm
11.4 cm
1.1 cm
Intel Cedar City Compute Stick M3-6Y30 4GB 64GB eMMC Windows 10 Bundle deal on Intel Cedar City Compute Stick M3-6Y30 4GB 64GB eMMC Windows 10
£471.40
saving £8.33
£388.41
BYQW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BYQW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.65
BYQW C2G 5m Select High Speed HDMI with Ethernet In Stock £22.20
BYQW C2G 10m Select High Speed HDMI with Ethernet In Stock £42.63
BYQW C2G 15m Select High Speed HDMI with Ethernet In Stock £57.72
BYQW C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Storage Type: Flash
Processor Model: M3-6Y30
Type: Personal computer
Case Style: Stick
Display: no
Optical Storage: None
Brand: Intel
Price Range Ex VAT: 150 - 300
