Modernize your data center storage and make the switch from HDDs to the Intel® SSD DC S3520 Series. As part of the Intel® 3D NAND SSD family of products, the Intel SSD DC S3520 Series delivers the unmatched combination of data integrity, performance consistency, and drive reliability. With a much lower active write power than the Intel® SSD DC S3510 Series, the Intel SSD DC S3520 Series enables the delivery of 35% more rack performance per watt.
- Intel Solid-State Drive DC S3520 Series - solid state drive - 800 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 800 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 16nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection, 3D NAND Technology
- 63 g
- 5-year warranty
- Capacity
- 800 GB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 63 g
Performance
- SSD Endurance
- 1663 TB
- Internal Data Rate
- 450 MBps (read) / 380 MBps (write)
- 4KB Random Read
- 65500 IOPS
- 4KB Random Write
- 17000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3.5 Watt (active) , 600 Watt (idle)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1000 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1000 g @ 0.5 ms
- Vibration Tolerance (operating)
- 2.17 g @ 5-700 Hz
- Vibration Tolerance (non-operating)
- 3.13 g @ 5-800 Hz
