The Intel SSD 750 series is Intel's first PCIe Gen3 x4 SSD developed for the client enthusiast and workstation markets. The Intel SSD 750 series is architected with the high performance controller interface - Non-Volatile Memory Express (NVMe) - delivering outstanding performance, low latency and Quality of Service. NVMe is a standardized interface that enables higher performance and lower latency than previous generations.
The Intel SSD 750 series is Intel's highest performing client drive specifically designed for the PC enthusiast and workstation systems with demanding storage workstation requirements. With PCIe Gen3 x4 support and NVMe queuing interface, the Intel SSD 750 series delivers excellent sequential read performance of up to 2.4 GB/s and sequential write speeds of up to 1.2 GB/s. The Intel SSD 750 series delivers random read IOPS of up to 440K and random write IOPS of up to 290K for 4 KB operations. Also, by taking advantage of the direct path from the storage to the CPU by means of NVMe, the Intel SSD 750 series exhibits low latency of less than 20 µs for sequential access to the SSD.
- Storage Capacity: 400 GB
- Maximum Read Transfer Rate: 2.15 GB/s
- Maximum Write Transfer Rate: 900 MB/s
- Drive Interface: SFF-8639
- Drive Interface Standard: PCI Express x4
Uncompromised performance
Maximize your computing experience with the Intel hard drive. By combining four lanes of PCIe 3.0 with state-of-the-art NVMe interface, the hard drive delivers exceptional throughput performance and latency in a client PC. The hard drive is truly advanced; utilizing NVM Express allows the hard drive to shed the burden of legacy AHCI commands. The Intel hard drive add-in-card (AIC) and 2.5-inch form factors enable excellent performance. -
NVM Express
NVM Express (NVMe) is a standard specification, architected from the ground up for non-volatile memory (NVM). NVMe significantly improves both random and sequential performance by reducing latency, enabling high levels of parallelism, and streamlining the storage command set. NVMe provides a standards-based approach, enabling broad ecosystem adoption for PCIe interoperability. -
Add-in-card and 2.5-inch SFF
With both add-in-card and 2.5" form factors, the hard drive eases migration from SATA to PCIe 3.0 without power or thermal limitations on performance. This allows the hard drive to deliver the ultimate in performance.
- Intel Solid-State Drive 750 Series - SSD - 400 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 400 GB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Interface
- Read Unrecoverable Bit Error Rate (UBER) 10e-16, Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, half-height half-length form-factor, S.M.A.R.T.
- 1.874 cm x 16.765 cm x 6.89 cm
- 195 g
- 5-year warranty
- Capacity
- 400 GB
- Interface
- 1.874 cm
- 16.765 cm
- 6.89 cm
- 195 g
Performance
- SSD Endurance
- 2.19 PB
- Internal Data Rate
- 2200 MBps (read) / 900 MBps (write)
- 4KB Random Read
- 430000 IOPS
- 4KB Random Write
- 230000 IOPS
Reliability
- MTBF
- 1,200,000 hours
- Non-Recoverable Errors
- 1 per 10^16
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe)
- Power Consumption
- 12 Watt (write) , 9 Watt (read) , 4 Watt (idle)
- OS Required
- Microsoft Windows 7 / Windows 8 / Windows 8.1 (64 bits)
- UL, VCCI, C-Tick, BSMI, WHQL, RoHS, KCC, WEEE, EN 60950-1 Second Edition, CEM, EN 61000-4-2:95, EN 61000-4-3:96, EN 61000-4-4:95, EN 61000-4-5:95, EN 61000-4-6:97, EN 61000-4-11:94, ENV 50204:95, ICES-003 issue 4, EN 55024:2010, EN 55022:2010, WHCK
- Limited warranty - 5 years
- 0 °C
- 55 °C
- 5 - 95%
- Shock Tolerance (operating)
- 50 g
- Shock Tolerance (non-operating)
- 50 g
- Vibration Tolerance (operating)
- 2.17 g @ 5-700 Hz
- Vibration Tolerance (non-operating)
- 3.13 g @ 5-800 Hz
