Product
Brand
Intel 750 Series 400GB Solid State Drive PCI Express 3.0 x4 (NVMe)
Quicklinx: BS9DWS00 Mfr#: SSDPEDMW400G4X1
The Intel SSD 750 series is Intel's first PCIe Gen3 x4 SSD developed for the client enthusiast and workstation markets. The Intel SSD 750 series is architected with the high performance controller interface - Non-Volatile Memory Express (NVMe) - delivering outstanding performance, low latency and Quality of Service. NVMe is a standardized interface that enables higher performance and lower latency than previous generations.
The Intel SSD 750 series is Intel's highest performing client drive specifically designed for the PC enthusiast and workstation systems with demanding storage workstation requirements. With PCIe Gen3 x4 support and NVMe queuing interface, the Intel SSD 750 series delivers excellent sequential read performance of up to 2.4 GB/s and sequential write speeds of up to 1.2 GB/s. The Intel SSD 750 series delivers random read IOPS of up to 440K and random write IOPS of up to 290K for 4 KB operations. Also, by taking advantage of the direct path from the storage to the CPU by means of NVMe, the Intel SSD 750 series exhibits low latency of less than 20 µs for sequential access to the SSD.
  • Storage Capacity: 400 GB
  • Maximum Read Transfer Rate: 2.15 GB/s
  • Maximum Write Transfer Rate: 900 MB/s
  • Drive Interface: SFF-8639
  • Drive Interface Standard: PCI Express x4
Intel Solid-State Drive 750 Series - solid state drive - 400 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
400 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
Read Unrecoverable Bit Error Rate (UBER) 10e-16, Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, half-height half-length form-factor, S.M.A.R.T.
1.874 cm x 16.765 cm x 6.89 cm
195 g
5 years warranty
400 GB
1.874 cm
16.765 cm
6.89 cm
195 g
Performance
SSD Endurance
2.19 PB
Internal Data Rate
2200 MBps (read) / 900 MBps (write)
4KB Random Read
430000 IOPS
4KB Random Write
230000 IOPS
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Power Consumption
12 Watt (write) , 9 Watt (read) , 4 Watt (idle)
Microsoft Windows 7 / Windows 8 / Windows 8.1 (64 bits)
UL, VCCI, C-Tick, BSMI, WHQL, RoHS, KCC, WEEE, EN 60950-1 Second Edition, CEM, EN55022:2010, EN55024:2010, EN 61000-4-2:95, EN 61000-4-3:96, EN 61000-4-4:95, EN 61000-4-5:95, EN 61000-4-6:97, EN 61000-4-11:94, ENV 50204:95, ICES-003 issue 4, WHCK
Limited warranty - 5 years
55 °C
5 - 95%
Shock Tolerance (operating)
50 g
Shock Tolerance (non-operating)
50 g
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
