Take your PC to a new level of responsiveness. Designed for work and play, the Intel® SSD 600p Series accelerates office applications, 4K video playback, HD content creation, and everyday gaming. Compared to traditional hard drives, the Intel SSD 600p Series delivers power efficiency, a small form factor for system flexibility, and 17x better performance. The Intel SSD 600p Series features the fast PCIe 3 x4 interface and is part of the Intel® 3D NAND SSD family of products. The only thing more amazing than Intel technology inside is what you’ll do with it on the outside.
Single-sided for design flexibility
The hard drive offers optimal in the single-sided M.2 form factor, enabling system designers the flexibility for thinner and lighter systems or more space for other components. -
Performance, that matters
The hard drive accelerates platform performance with high sequential read and write speeds and random read and write input/output operations (IOPS). With the hard drives, integrated in the PC system, users will work more efficiently with the applications, they care about, with better performance. -
Charge your device less often
The hard drive provides extended battery life through low power modes. It reduces idle consumption, reducing power consumption. When coupled with a powerful processor-based platform, the advanced power mode settings reduce power consumption by another order of magnitude.
- Intel Solid-State Drive 600p Series - SSD - 1 TB - PCIe 3.0 x4
- Solid state drive - internal
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- M.2 2280
- Interface
- PCIe 3.0 x4
- Smart Response Technology, Rapid Start Technology
- 5-year warranty
- Capacity
- 1 TB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- PCIe 3.0 x4
Performance
- Internal Data Rate
- 1800 MBps (read) / 560 MBps (write)
- 4KB Random Read
- 155000 IOPS
- 4KB Random Write
- 128000 IOPS
Reliability
- MTBF
- 1,600,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe)
- Compatible Bay
- M.2 2280
- Power Consumption
- 100 mW (active) , 40 mW (idle)
- RoHS
- Limited warranty - 5 years
- 0 °C
- 70 °C
