Your basket is empty
Intel 160GB S3500 Series 2.5" SATA 6Gb/s Solid State Drive
Quicklinx: 93VLWS00 Mfr#: SSDSC2BB160G401
Form Factor: 2.5"
Capacity: 160GB
Interface: Serial ATA-600
Type: Internal hard drive
£132.52 ex VAT
£159.02 inc VAT
The Intel SSD DC S3500 Series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9% of the time) along with a tight distribution of up to 75,000 input/output per second (IOPS) delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
Intel Solid-State Drive DC S3500 Series - solid state drive - 160 GB - SATA 6Gb/s
Solid state drive - internal
160 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), End-to-end data protection (ANSI), SMART Command Transport (SCT), Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, S.M.A.R.T., 256-bit AES
60.95 mm x 100.45 mm x 7 mm
70 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
160 GB
2.5"
SATA 6Gb/s
60.95 mm
100.45 mm
7 mm
70 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
475 MBps (read) / 175 MBps (write)
4KB Random Read
75000 IOPS
4KB Random Write
7500 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.5 Watt (active) , 0.9 Watt (idle)
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, CISPR 22, FCC Part 15 B, RoHS, UL 60950-1 Second Edition, KCC, EN 60950-1 Second Edition
Package Type
OEM
Limited warranty - 5 years
70 °C
5 - 95%
Shock Tolerance
1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Form Factor: 2.5"
Capacity: 160GB
Brand: Intel
Price Range Ex VAT: 100 - 150
