Product
Brand
Infocus Wireless Display Link
Quicklinx: 74MRWS00 Mfr#: SPDOUSBWIRELESS
Wireless freedom over USB
InFocus introduces another wave of wireless freedom to projection. The new InFocus Wireless DisplayLink adapter replaces USB cables for your DisplayLink enabled InFocus projector, giving you the freedom to present wirelessly over USB, from anywhere in the room. Plug and project ease coupled with wireless USB technology provides point-to-point connectivity of up to 30 feet / 10 meters without cables. Simply connect the pre-paired adapters into the USB ports between the computer and your InFocus projector and begin presenting. With Wireless DisplayLink adapters, connectivity has never been so simple.
Simplicity
The Wireless DisplayLink adaptor contains all the necessary software in an onboard driver, supporting a true plug and project experience with current Windows based operating systems.
Flexibility
Both Wireless DisplayLink adapters are powered via the USB connectors so no external power is required and, because they are about the size of your average USB thumb drive, they'll fit into any briefcase, laptop bag or accessory pouch. Both male and female adapters are designed to connect and rotate to three different positions for maximum flexibility in tight spaces.
Performance
With a one-to-one connection between any PC or laptop and our DisplayLink enabled projectors, the Wireless DisplayLink adaptors provide crisp and clear images delivered with fast and reliable Ultra Wide Band (UWB) technology.
Security In One
The USB compliant adapters have a proprietary relationship and are factory pre-paired to ensure secure transmissions up to 99 Mpbs over a 128 bit encryption protocol. Project seamlessly and securely over distances up to 10 metres.
