Infocus IN5312 1024x768 4500 lumens XGA DLP Projector
Quicklinx: BLLVWS00 Mfr#: IN5312
Bring clear communications to your large conference room or classroom! The InFocus IN5312 is a versatile XGA projector for professional installations - and a great value. Stunning DLP image quality, brightness, and flexibility are all vital and the IN5312 has them covered and then some. A broad range of connectivity, three lens options, and a small form factor help it fit into a wide variety of venues, such as large classrooms or conference rooms and houses of worship.
  • Stunning HD resolution with vivid detail
    The IN5312 features the DLP technology and BrilliantColor enhancement for vibrant, true-to-life images in vivid detail.
  • Get the ideal image and projector placement
    The IN5312 DLP projector has the features for easy installation into a wide variety of venues.
  • Digital and analog connectivity for legacy installations
    The IN5312 has a full set of inputs for digital installations as well as legacy analog installations.
InFocus IN5312 - DLP projector - standard lens - 3D
DLP projector
3D Capable
Ethernet, Fast Ethernet
Microdisplay
DarkChip 3
Brightness
4500 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
UHP 330 Watt
Bulb life cycle
Up to 1500 hour(s) - normal mode , Up to 2000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
40.1 cm x 31.9 cm x 11.1 cm
4.8 kg
DLP projector
3D Capable
Ethernet
Projector
Microdisplay
DarkChip 3
Brightness
4500 lumens
Contrast Ratio
2000:1
Throw Ratio
1.6 - 2.0:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 106 kHz
Bulb type
UHP 330 Watt
Bulb life cycle
OSD Languages
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Korean
Eco-Mode technology, Wireless Ready
Lens
Standard lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.25x
Lens Shift Type
Manual
Vertical Lens Shift
0% / 40%
Horizontal Lens Shift
5%
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, DVI
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Speakers
2 x right / left channel
Input Device
External
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-D input - 24+1 pin digital DVI , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 1 x component video input - BNC x 5 , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
Lens cover, wireless remote control
1 x VGA cable , 1 x A/V cable
UL, cUL, FCC
40.1 cm
31.9 cm
11.1 cm
4.8 kg
Limited warranty - parts - 2 years , Limited warranty - labour - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
34 dB
BLLV C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
