The InFocus IN2126a widescreen projector combines high brightness, networking and low cost – making it perfect for the office with larger rooms and low budgets.
- InFocus IN2126a - DLP projector - standard lens - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Localisation
- Worldwide
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Standard lens
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263, RV3, RV4
- Storage Capacity
- 2 GB Flash
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- 29.2 cm x 22 cm x 10.8 cm
- 3.2 kg
- 1-year warranty
- 3D Capable
- Built-in Devices
- Speaker
- Localisation
- Worldwide
Projector
- Brightness
- 3500 lumens
- Brightness (Reduced)
- 3200 lumens
- Contrast Ratio
- 15000:1
- Throw Ratio
- 1.5 - 1.8:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
- Eco-Mode technology, Blackboard Mode, 6-segment colour wheel, Closed Caption, JPEG photo playback, MP3 playback, DLP 3D Ready, 16:9 aspect ratio support, Whiteboard Mode, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, 4:3 aspect ratio support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback, MP2 playback
Lens
- Standard lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- Digital Video Format
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI input - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar
- UL, cUL, FCC
- 29.2 cm
- 22 cm
- 10.8 cm
- 3.2 kg
- Limited warranty - 1 year , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- 0 °C
- 40 °C
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
