The InFocus IN2124a projector combines high brightness, networking and low cost – making it perfect for schools with larger classrooms and low budgets.
- InFocus IN2124a - DLP projector - standard lens - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Localisation
- Worldwide
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens
- Standard lens
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263, RV3, RV4
- Storage Capacity
- 2 GB Flash
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- 29.2 cm x 22 cm x 10.8 cm
- 3.2 kg
- 1-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Localisation
- Worldwide
Projector
- Brightness
- 3500 lumens
- Brightness (Reduced)
- 3200 lumens
- Contrast Ratio
- 15000:1
- Throw Ratio
- 1.9 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
- Eco-Mode technology, Blackboard Mode, 6-segment colour wheel, Closed Caption, JPEG photo playback, MP3 playback, DLP 3D Ready, 16:9 aspect ratio support, Whiteboard Mode, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback, MP2 playback
Lens
- Standard lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- Digital Video Format
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI input - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar
- UL, cUL, FCC
- 29.2 cm
- 22 cm
- 10.8 cm
- 3.2 kg
- Limited warranty - 1 year , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- 0 °C
- 40 °C
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
